How to clear error code 3921 on bizhub c3850 - Office Equipment & Supplies
4 Suggested Answers
  • 51 Answers
SOURCE: Bizhub C253: Error Code C-4551 will not clear.
open front door and switch-off machine
press utility buton hold press-on then swietch-on machine, on the screen right top corner u see dot (remove finger from utility buton)
after fue second u will see trouble reset touch under u will see ok switch-off machine wait 10 sec and switch on
If the error code still is on the machine u have to change cyan laser
Posted on Oct 09, 2009
Bizhubman
  • 108 Answers
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
Posted on May 19, 2010
copyalbania
  • 44 Answers
SOURCE: My Minolta Bizhub-200 prntr. has a C2557 error
moz-screenshot.pngmoz-screenshot-1.pngC2557 - Abnormally toner detected black tcr sensor.
Reinstall image unit black
Reinstall toner cartridge
Change Image unit
Change toner carridge.
Posted on Aug 12, 2010
How do i clear error code c4154 on bizhub c250
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Oct 17, 2015 | Konica Minolta bizhub C250 All-In-One...
Bizhub c3850 printer offline
what does it copyis displayed on the control panel???????????????/
does it copy????
Apr 07, 2014 | Konica Minolta Office Equipment & Supplies
How to solve M2 in bizhub 164
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Feb 23, 2014 | Minolta bizhub 200 All-In-One Printer
ERROR CODE 3921 BIZHUB 450
replace the fuser unit.
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Then reset.
use this procedure:
Feb 03, 2014 | Konica Minolta bizhub C450P Laser Printer
TROUBLE CODE C-3921 BIZHUB c451
ERROR C-3921
Jan 30, 2014 | Konica Minolta Bizhub C550
C280 error 3921
Do once if the code comes back replace the fuser unit or the fuser can catch on fire continuing to reset the machine ruining a perfectly good day.
4. Check to make sure that [OK] is displayed and it has been reset.
Jan 27, 2014 | Konica Minolta bizhub C450P Laser Printer
Reset err code c-3921 bizhurb c451
You might Google the printer name and the error code. This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. You will loose any settings and any work in progress. Just a guess. If you have an owners manual, I would check there to find how to solve the problem. There is normally a section that defines the error codes and gives solutions. You also might want to enter the "menu" if there is one, and discover whether you can solve the problem there. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section. Good luck.
Nov 11, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error c3921 konica minolta c451 error c3921 not known what to do
C3921: Fusing sensor wire breaks detection (Center of the heating roller)...
• At the warm-up stage, the heating roller
thermistor/3 voltage does not decrease by
predetermined steps (temperature rise)
within a predetermined time.
Check the fusing unit for correct installation
(whether it is secured in position).
Check the open/close operation of the
upper right door.
Check the fusing unit, IHPU, PRCB and
REDB for proper connection and correct or
change as necessary.
If that check still give you error code 3921
Change fusing unit
Mar 16, 2009 | Konica Minolta bizhub C450P Laser Printer
k24674
