I have a thin line running down the side of my screen that doesn't go away.
    Sergeant:
  • 231 Answers
A new screen or television will fix that right up. Sorry to sound so brash but that is something that cannot be fixed that I know of, unless if you put a little twist or squeezing pressure on the chassis, and it blinks off, (not too much) then a connection cleaning or re-positioning should fix it. You would need to be a technician type person to take the unit all apart to fix.
Posted on May 03, 2017
Have sony model KdL 40S2000, now has colored thin lines going up and down on the left side. Anyone know the cause.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD screen is given with illustrations.
Jul 29, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
Hi I have two blue lines running down my laptop
Sounds like you screen is going bad. If the lines are there all the time the you will need to replace you screen to fix the problem.
Jul 14, 2010 | Compaq Presario M2000 Notebook
My laptop screen has a thin blue line going down, why has this happened?
You have the beginning of a failing Display panel, and will eventually need to replace the display.. you can hold the top left and right sides of the display screen-slightly bend forward and back, you should see the blue line either go away or it will produce more lines...
This is due to a short on the circuit board panel on the backside of the display panel that controls the Pixels on the Screen.. The Pixels are controlled In a Line Grid Fashion...
Nov 16, 2009 | Dell Inspiron E1505 Notebook
Vertical white line on laptop display
Yes, this is a defective screen. The only fix is to replace the screen. It's called a column of dead pixels. Since it is under warranty, contact HP to have them warranty it out or take it back to the place you purchased it from for an exchange. Please take a moment and give this answer a good rating of fixya. Thank you.
Dec 26, 2008 | HP Pavilion dv7-1130us laptop
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Very thin vertical lines on display that won't go away
This might be a software issue with your video driver (follow Microsoft's built-in Help to test that, and look for an updated driver for your particular hardware) but it is fairly unlikely to be a driver issue. The thin lines running through your screen are usually due to screen failure -- hope you have your warranty, because this is a hardware issue and usually pretty expensive if you're out of pocket.
Aug 01, 2008 | Toshiba Satellite P105-S6104 Notebook
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
