Question about GE Kitchen Ranges
I need a part # for switch valve on GE profile gas range JGSP44AEY2AA
ngafm
  • 166 Answers
SOURCE: GE Profile gas range
hello dreeden5
Ngafm at your service,
You have a GE Profile oven range. I and you just cleaned it and the pilot light on all four burners continues to click on and off.
It sounds like the gas line or the gas valve, have some debris in them!
They need to be evacuated by an experienced tech.
This time you need service.
Bless You ngafm
Please give me a good rating at this sight before you leave!
Thank You
Posted on Sep 11, 2008
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
MNTECH
  • 1543 Answers
SOURCE: GE gas range igniter continues to spark, won't shut off.
Often times, just leaving the range unplugged for a time will solve the problem, which is most often caused by water or a cleaning agent getting into an igniter switch behind a burner knob. After the switch drys out it usually starts working again. In the mean time, you can still use the burners by lighting them manually with one of those long lighters, but you will not be able to use the oven or broiler without electricity. If the range continues to spark after being left unplugged for more than a day or two, you will have to determine which switch behind the burner knobs is causing the problem. Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Posted on Feb 18, 2009
  • 291 Answers
SOURCE: GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Posted on Apr 01, 2009
SOURCE: Panel of GE profile gas range says 'LOC ON', how
This is the controlled lock out mechanism so that your children cannot play wilth the controls. Press "0" and "9" at the same time and hold them until it says "LOC OFF."
Posted on May 23, 2009
GE profile JGSP44 Oven stopped working
Ignitor needs to be working for the gas valve to open. If the ignitor does not reach the proper amp draw the gas valve will not open. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru performing an amp draw test on the ignitor.
Mar 28, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
See if the oven safety valve is OPEN if it is then you won't get the ignitor glow.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The gas ignitor keep ticking in off or on positions
There is a spark switch on each gas valve. One or more of your spark switches is defective.
Remove the front panel over your valves. Unplug each switch until the sparking stops. That will be the bad switch. Replace it.
Mar 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Jan 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter on Burners Firing
Located on top each burner control valve is a switch that controls the igniters. One or more of these switches has failed
Dec 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44
there is switch behind the knob it most be wet or it needs to be replace they are call,top burner valve switches. white in color plastic.
Nov 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
hello dreeden5
Bless You ngafm
Thank You
Sep 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven gas valve wont come on
your valve is bad replace it the ignitor needs to darw a min of 3.5 amps to open the valve if it is drawing the amps then the valve is bad
Jan 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP85WEB5WW
im assuming you dont have to light the pilot.if thats the case and you replaced the ignitor assembly it could possibly be the ignition module/board.
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
