Question about Kenmore Washing Machines
Kenmore laundry center 36361542410. Dryer works but nothing works or lights up on the washer.
  • 156 Answers
SOURCE: Kenmore Laundry Center #417.90802990
unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
Posted on Feb 28, 2008
  • 1314 Answers
SOURCE: Dryer Squeaks
ok your having the begings of a rear bearing problem now let me tell you whats happing if you pull the dryer out and look about at the middle of where the drum is at the back then you will see a silver small rectangle peice in the middle of that is what looks like a small finger with a steel ball under it on the little ledge there should be a little pile of black dust the little finger is making the little ball cut into the back of the rear bearing but the rear bearing is still good now get you a little can of spray lithem grease clean the dust off turn the dryer on and spray that little ball till its coated then every time you hear it squel repeat the proceadure untill one day it wont stop then we will have to change it and on that day you better have some help lol
Posted on Mar 31, 2008
  • 958 Answers
SOURCE: dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Posted on Oct 11, 2008
  • 172 Answers
SOURCE: igniter on my gas dryer glows but does not ignite
If the ignitor is infact getting hot enough the next step is for the coils to open the valve to release the gas. Most of the time the ignitor is not drawing the proper amperage to open the coils. One or more of the following parts would be bad.
ignitor # 5303937186 $50.00 shipped to you.
coil # 5303931775 $40.00 shipped to you
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
  • 686 Answers
SOURCE: how do you replace drain hose kenmore laundry model 41797812700
take off the hose clamp and pull it right off
Posted on Apr 03, 2009
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
When I put a light load into washer, follow directions, the washer starts by running water but does not go into next cycle
I would check the lid switch. If switch is faulty, it will allow unit to fill like normal, but won't agitate or spin.
Nov 15, 2015 | Kenmore 24 in. Gas Laundry Center with...
There is a thermal limit fuse on the rear of the machine.
Check it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore laundry center stacked washer/dryer washer tub shakes almost violently on spin cycle.I may have changed setting during spin cycle.Tub is off balance.The appliance cabinet is balanced and on a solid...
Head over to the manufacturer's website.
www.SEARSPARTSDIRECT.com and enter your full model number for an expanded parts diagram and ordering information.
Apr 11, 2009 | Kenmore Washing Machines
Feb 28, 2008 | Dryers
Washing Machines Logo
41 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
