Question about GE Refrigerators
I need a part # for switch valve on GE profile JGSP44AEY2AA
GE Profile water pouring from ice maker
shut off the water to the unit and sounds like either the disp switch is stuck or the water valve faulty.
Apr 02, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE JGP 945 continues to spark. Removed all igniters but continues to click. Bad Spark Module?
no,its a bad switch on one of the gas valves,they are piggybacked on the gas valve and are supposed to turn on and off as the valve is turned on and off,on has broken and is on all the time even with that valve in the off position,carefully remove each switch from the circuit till it no longer sparks with all the valves in the off position
Mar 30, 2011 | GE Profile JGP636 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
Ge model jgp326 ignitor is giving
you either have a bad licon switch on one of the burner valves or you got water or cleaner in one of the switches.. Unplug it and let it dry for a few days, if it does not work you need a new switch.
Nov 11, 2009 | GE Profile JGP636 Gas Cooktop
My GE profile is not dispensing water and ice
Either your dual water control valve is defective on both sides or you need a new door switch. Have someone check the power to the water control valve wile someone presses dispense. Sea Breeze
Aug 25, 2009 | GE Refrigerators
Dishwasher will not fill up with water
did you chek the level micro switch thats in serie with the intlet valve
Jun 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
The water will not stop coming out of the door dispenser
1 of two things. 1)the switch at the dispense flap has failed. 2) the water valve solenoid that the sitch activates has failed. you will need to pull the unit away from the wall and remove the bottom panel...on the right side you will see the valve assembly. remove the power connection to the vavles....then turn your water on...water out of dispenser means bad solenoid/ water means bad dispenser switch.if its the switch you can leave the solenoid to the dispenser unplugged until you get the part.
Jun 11, 2009 | GE Profile Stainless Bottom-Freezer...
Igniter on Burners Firing
Located on top each burner control valve is a switch that controls the igniters. One or more of these switches has failed
Dec 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44
there is switch behind the knob it most be wet or it needs to be replace they are call,top burner valve switches. white in color plastic.
Nov 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Water Dispencer switch is very slow to close off.
The problem may be in the electric valve in back of the refrigerator that supplies the water to the door dispenser. A small particle maybe lodged on the seat of the valve causing the slow closing and dripping. Replacing the water valve assembly may solve your problem. I would also recommend installing an in line water filter before the entrance to the valve.
Jun 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
