Question about Garden
Xmark quest will not move. Wheels seem locked.try to move forward or backward nothing happens,but hydros groan like they are trying to move.
SOURCE: Gears of war problem
Simple fix for forward-back movement axis inversion:
In "My Documents\My Games\Gears of *** for Windows\***Game\Config", edit the file "***Input.ini". At the very top, under the section "[Engine.PlayerInput]", change your MoveForwardSpeed to a negative number, like this:
Note that I only play offline, and this setting in this file works great for me with Logitech Rumblepad 2 (although all of the other buttons are still a little off, but that I can live with). I tried every other reference to forward-backward movement and the left Y axis in this file, as well as "<installdir>\Engine\Config\BaseInput.ini" and "<installdir>\***Game\Config\DefaultInput.ini", so don't bother with those...
Posted on Mar 10, 2008
  • 109 Answers
SOURCE: Honda Harmony mower, self propelled hydrostatic,
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
Posted on Apr 26, 2009
SOURCE: The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Posted on Jul 01, 2010
  • 200 Answers
SOURCE: won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
SOURCE: power seat won't move backwards
I had the same problem some one on one of the web-sites solved his problem by banging on the track rail in the front while pushing the seat button back after a good few bangs it unjamed and works great now .I feel like I saved at least $1500 by dealer rates.
Posted on Aug 19, 2010
When I release the clutch on my 42 inch, Craftsman II, Diehard, it won't move forward or backwards
Sounds like the drive belt isit running as fast as the pulley it is either stretched or has come off not getting power to wheels.
Jul 26, 2017 | Craftsman Garden
How do I unlock the rear wheels, I got a Poulan Riding Mower from a late Uncle. It won't roll forward or backwards
Kevin, if it is in neutral or if it is hydro-stat, you have pulled the pins in the back to unlock the axles. the brakes may be locked up. the last two mowers i got for some reason the brakes were locked up on them both. hope this helps.
Dec 16, 2016 | Poulan Garden
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
My 1995 BMW 318ti (standard) turns on fine and the clutch goes into gear but when I tried to reverse the car tried to move but the back wheels were locked up or something! ! I can shift the clutch into...
ok this is gonna sound ridiculous, but if the wheels are locked, did you take off the handbrake?? also, the clutch might not be engaging properly.
Aug 18, 2017 | BMW 318 Cars & Trucks
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My mountfield petrol mower wont allow the wheels to go backwards, it goes forwards fine, also i used to be able to stop it moving forward by just relasing one of the handles now i have to release both -...
there is a gear with a key on each axle the key is made so that it locks in one way and free wheels the other way they are prob rusty pull apart clean and use anti seize on them. do you hose off the mower ? if so try to not get the water in behind the wheels
Aug 31, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
