Dark spots appear on edges of tv. Also across entire lower 2/3 at times. 45inch LG. No cable antenna only but worked great until about a week ago. Thank you for your help.
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on May 03, 2017
LG Tv M227WDL HDMI black screen
If the HDMI input is failing you will need to ring Customer Support or Get a New TV because if its not outputting then The HDMI may not get Prosecced (sorry about spelling) And make sure you have checked its the Correct port and that there is no Blue-Tac or dust in the port ( that ussually solves this) If all else fails Use a Hairdyer and give it a Big clean :D
Mar 14, 2014 | Televison & Video
LG47lc7df Antenna signal
It is possible you are experiencing tuner problems. If you cannot pick up any channels regardless of the antenna used, sounds like tuner problems.
Nov 02, 2013 | LG Televison & Video
HELLO WE HAVE A 60INCH 60PS40FD STILL IN WARRANTY AND INTERMITTENTLY IN EXACTLY THE LOWER HALF OF THE SCREEN HORIZONTAL LINES APPEAR FOR NO REASON CAN FLICKER.AS IF EVER SECOND LINE ON THE SCREEN GOES...
shaun851, If set is still covered under Lucky Goldstar warranty, then don't you dare let them off the hook. The problem could be in the units internal "switch-mode-power-supply" or any other signal processing circuit that requires clean, noise-free, DC voltages and current. Call or email a complaint to LG with the model, serial, and date of manufacture of the unit. One other thing you can do would be is locate local TV service shop or even a Best Buy and question the technicians there to see if this type of symptom is common with this model and what corrective actions (fixes) were implemented. You should also note the exact symptom characteristic's, such as "lines appear after 4min of operation" or "lines appear 5 seconds after turn-on" and what type of signal source you are using or viewing. e.g. dvd. cable, antenna, vcr. My only suggestion to you if unit will be serviced is that you make sure the technician informs you of the ROOT CAUSE of failure!! Start the warranty service request today. Do not wait. Hope this has helped. I worked for Zenith many years ago till LG took over and 50 percent of employees went out the door. Good luck with the repair. 12fixlouie
Apr 07, 2010 | LG MU-60PZ95V 60 in. Plasma HDTV
Hitachi lcd projection tv screen discoloration model 50vs69a
probabally a dust spot on the mirror or the lcd mini panels inside the optical engine.
must be dissembeled to clean.
not for the faint of heart.
Jun 13, 2009 | Hitachi 50VS69 50" Projection HDTV
Lines across the screen
the dark lines could be what is called hum bars these are caused by ground differences between cable and your AC ground. check to see if these lines appear using a dvd and removing the cable from the cable box. if the lines disappear then call the cable company and your electricain. in the mean time you can use a plug adaptor that is the 2 prong (ground less) until you can have the problem fixed. but don't use the adaptor as a fix, for your TV is a computer and needs proper grounds.
Apr 14, 2008 | Mitsubishi Diamond WD-65831 65" Projection...
Mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Feb 16, 2008 | Mitsubishi WD52527 52" Projection HDTV
Cable question
Make sure your refresh rate is set no more than 60HZ. Your monitor might not support refresh rates higher than that.Also try lower resolutions.
Here is a list of specs: (also try another cable)
Features/Specifications:
  • Olevia LT23HVX 23-inch HDTV Compatible Widescreen LCD TV
  • General Features:
  • Black cabinet
  • 23-inch active screen size
  • 16:9 widescreen aspect ratio
  • HDTV Compatible
  • 1366 x 768 native resolution
  • 1600:1 contrast ratio
  • 8 ms response time
  • 178° horizontal and vertical viewing angle
  • NTSC TV system support
  • 480i, 480p resolution support
  • Progressive scan
  • Color temperature adjustment
  • Built-in 5 watt x 2 speakers
  • PC resolution support up to 1024 x 768 @ 60Hz
  • English/French/Spanish language
  • Sleep Timer
  • V-Chip parental control
  • Energy Star compliant
  • Remote control included
  • Wall mountable
  • Front Panel Features:
  • IR sensor
  • Power
  • Menu
  • Channel down
  • Channel up
  • Volume +
  • Volume -
  • Source
  • Rear Panel Features:
  • 15-pin VGA
  • Audio in
  • Headphone
  • Component Y, Pb/Cb, Pr/Cr
  • Composite RCA video inputs
  • S-Video
  • Antenna
  • Power Specifications:
  • 100-240V, 50/60Hz, 2.5A (max)
  • 110 watts AC power consumption
  • Unit Dimensions:
  • 16.5 x 27.1 x 8.3-inches (H x W x D)
  • Gross Weight: 23 lbs
  • Net Weight: 21 lbs
  • Regulatory Approvals:
  • FCC
  • CSA
  • UL
Package Includes:
  • Quick Start Guide
  • Manual
  • Remote control w/two AA batteries
  • Power cord
Additional Information:
  • Notes
  • Model: LT23HVX
  • Product Requirements:
  • Satellite cable or antenna
  • PC with 15-pin VGA adapter
  • Stereo system with component, S-Video and composite jacks
  • Available power outlet
  • Disclosures:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 20-Inch to 23-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15mm (bright to bright dots)
  • Minimum distance between defects: 5mm (dark to dark dots)
  • Disclosures:
  • Consumer Notice:
  • This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the Nation’s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission’s digital television website at: www.dtv.gov.
Nov 29, 2007 | Olevia LT23HVX 23 in. LCD Television
Inteligent eye Not Working
try this....clean sensor with denatured alcohol..may have fingerprints or etc.
Aug 30, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
