Question about Inverter Electronics - Others
Is it safe to use a, pure sine grid tie inverter to use on a rv battery bank?
  • 78010 Answers
SOURCE: i have samlex 600 watt
replace the inverter diodes, they are most likely burned out
Posted on Jun 18, 2009
  • 4090 Answers
SOURCE: I had my inverter stored and when I connected it
did you check the fuses there should be two one for AC one for DC ( depends on brand and quality) If not then I would suspect a breakdown of the power transistor.
Posted on Aug 20, 2009
  • 61 Answers
SOURCE: In my question as to
this solution would likely work fine if you were only looking to have 110vac power. In order to have 220vac from two 110vac devices, you would need expensive equipment, and technical knowledge.
What you need to do in order to get 220vac is buy an inverter that will provide 220vac. There are many available.
Hope that helps.... Good Luck!
Posted on Nov 27, 2009
  • 70 Answers
SOURCE: I have a pure sine wave power inverter 1000watt -
check the fuse on the unit
Posted on Jun 12, 2011
  • 1044 Answers
SOURCE: i need an inverter for
The most important spec that you will need is the LRA rating. What this stands for is locked rotor amps. The LRA rating is what the AC unit will draw from the inverter while the compressor starts up. This is a very important spec when sizing an inverter for use with an AC unit. After you get this spec you will multiply it by the voltage and this will be the startup wattage needed by the inverter.
For example if your LRA is 60.6 amps if you multiply this by 115 you will get roughly 7000 watts at start-up.
The next thing to take into consideration for a AC unit is battery bank size. Your next step in setting up a system for use with an AC unit is finding a sufficient recharge source for the batteries. You will want to have a minimum of a 150 amp alternator to recharge a system with a small AC. I do not know whether you will be able o accommodate them.
Why don't you go for solar power as standby OR a small generator????????
Posted on Aug 05, 2011
Testimonial: "Thank you very much for the information. It has been very helpfull."
Dometic brisk 2 AC can it be operated on a 24 volt inverter.
If your inverter puts out enough power, sure. It may drain your batteries pretty fast, though. Check the power rating of your AC and compare it to the power output of the inverter. Add a safe margin for everything else you want to run at the same time.
Oct 29, 2015 | Dometic Rooftop RV Air Conditioner
I have a 32" TV in my RV. It is run from an inverter from the 12v batteries. batteries show 12.8 volts. TV only has sound and a blue screen.If I connect the RV to mains the batteries are then being ch
Possible that the voltage from the inverters is not equal to what is available from the mains? Something in the inverters output is preventing the tv from working properly.
Aug 19, 2017 | Electronics - Others
Why is my pure sine wave keep blowing fuses?
please check if all attached connection are tight .Sometimes loose wire connection also causes fuse blow
Sep 15, 2014 | Electronics - Others
Need owners manual
Without knowing make or model other than 600 Watts and pure sine output:
is for a series of pure sine inverters, yours should be similar enough to the 600 Watt version to be of practical use.
Jan 14, 2012 | Inverter 600 Watt Pure Sine Wave
Manual, for a aims 1500 pure sine inverter, not putting out. need manual or help in diagnosing the problem
The manual for aims1500 pure sine inverter is not available. The particular manual for this inverter is not not available.
Click the below link and check the inverter manual. You might find it helpful.
Click here:
Jun 04, 2011 | Vacuums
My husband hard wired an inverter for our RV to run the TV & associated equipment. It powers them fine but the reception has lines and dots running through it when on the inverter. We purchased a sine...
It is becaus the inverter erradiate EMI (Eletro Mechanical Interference) and the EMI is picked up by the TV antenna, try moving them a part as far away as you can from each other (the inverter and the TV antenna), there are also some filters you can pusches, but enven with all that stuff you could end up with EMI any way so don't spend to much,
Apr 20, 2011 | Electronics - Others
Can this model be used on the grid? If not, is there a sunforce inverter that can be used on the grid?
If you meant for the mains supply then it must be connected in series to the load so that in absence of power the invertor takes over and when there is power the supply takes over as it charges the battery.
So have this wiring done with the connection routed from the fuse box or main board.
Sep 30, 2010 | Sunforce 1000 Watt Pure Sine Wave Inverter...
Frequency Inverters DC-AC
I highly suggest you invest in a good quality inverter. For most equipment either pure or modified sine wave is fine. I would suggest you install a line conditioner after a UPS for any computer products. The line conditioner stabilizes the voltage much more closely than a UPS will.
As far as building your own, I've taken apart a lot of UPS models which have a DC-AC converter in them and they are filled with lots of heavy heat sinks, transistors, resistors, capacitors, etc. You can usually find these very cheap since the batteries die but the converter is fine. Check the input voltage of the original unit and start from there to make one easily that has everything already assembled with minor modifications.
Jan 15, 2018 | Xantrex Technology Ags Harness Cable...
Run a CPAP on a power inverter
I would not do this, you really need a pure sine wave inverter to guarantee the safety of your CPAP machine. At the price they are selling this device it could not be pure sine wave. 150W pure sine wave would be $70-$100.
Mar 05, 2009 | Thermal Engineering Corporation I-Tec 150...
Electronics - Others Logo
304 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
