Question about Whirlpool Dryers
Will a whirlpool door switch fit properly into a kenmore? The serial #'s are the same for the door switch so I'm a little confused. Thanks
  • 32 Answers
Yes if your kenmore dryer modle no start with 110.....
Posted on May 04, 2017
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Jun 21, 2014 | Kenmore 659 Electric Dryer
Kenmore H2 Plus door won't open.
see the causes and fix it: God bless you
irst to unlock depending on model. There will be a pull tab either under the lower kick panel, behind the filter cover, or under the top panel. Pull this tab to unlock the door. Now you can remove the clothes and water. Refer to the owners manual for the location of your emergency door pull tab.
Door Switch
You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Jul 18, 2012 | Kenmore Washing Machines
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
It's a Kenmore Model 106-56712500 , can't shut off alarm after changing filter, and now won't make ice or dispense water! How do I do a proper re-set code?
The 106.xxxxoooo Models are made by Whirlpool.
  • Whirlpool and KitchenAid - press the light switch 5 times within 10 seconds.
  • NOTE: If the fridge has a filter button, press and hold it for 5-10 seconds.
  • Changing the water filter should not cause the water and ice in door to not work. The actual freezer door switch will cause this problem. When the door is open ice and water in door are disabled. The door switch is a 3 contact switch. One contact is common, one turns the light on / off and one disables / enables ice and water in door. Manually depressing the door switch in the door fold hinge area should enable the water in door function. Do NOT test the ice function. If after you depress the light / door switch the light does not go out and the water in door does not work then the door switch has failed. The door switch is released from the cabinet by sliding either a putty knife or a knife blade along one side to unlock the locking tab. If the switch only has 2 terminals you have removed the wrong door switch. Check the other door.
    If your refrigerator has the wiring harness on the bottom of the door hinge there is the possibility that during the water filter change the connection of the door wiring connectors was loosened or broken. Just check to make sure that there is not a harness on the bottom of the door hinge. If there is a harness on the bottom of the door hinge make sure the connectors are connected.
    If you need more assistance just respond here and I will gladly help you.
    Thanks for choosing FixYa,
    Kelly
    Jan 11, 2011 | Kenmore Refrigerators
    I have a whirlpool model number GEQ9800PW1, the serial number is MS2024548. I just noticed tonight that when I opened the door the light didn't come on, I thought well I can live with that, but when I...
    door switch: http://www.partselect.com/dryer+replace-door-switch+repair.htm
    to open dryer: http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
    can buy at a appliance repair/service shop, online or eBay. Good Luck Tim
    Nov 29, 2010 | Whirlpool Dryers
    Whirlpool washer duet is flashing after adding garmet. Will not return to washing
    April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
    MODELS: See additional page for Kenmore model numbers
    COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
    CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
    PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
    MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
    Heat cycle stops/goes off
    1. Changing from 3 to 4 wire hookup on a electric dryer
    2. Door switch replacement help for a common door switch
    3. Dryer basics - Venting problems and power supply
    4. Dryer basics - timers and how they work
    5. Dryer basics - power cord problems
    6. Dryer basics - dead dryer
    7. Dryer *general* repair flow chart....Click here
    8. Gas dryer smell
    9. How do dryer thermostats work?
    10. How long can my dryer vent be in length?
    11. How to change a common rear drum seal
    12. How the belt is suppose to look at the motor and idler pulley
    13. Help on replacing dryer motor and some wiring tips for the 279827 motor
    14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
    15. Help for storing an appliance
    16. Important Disclaimer
    17. I dropped something down the lint filter area....help!
    18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
    19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
    20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
    21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
    22. Inglis, Whirlpool and Kenmore electric element changing procedures
    23. Inglis, Whirlpool and Kenmore dryers - air flow
    24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
    25. Inglis, Whirlpool and Kenmore style dryers - belt change
    26. Inglis, Whirlpool and Kenmore dryer general motor problems
    27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
    28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
    29. If your drum belt looks like either of these....change it!!
    30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
    32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
    33. Pilot flame help
    34. Sample wiring diagrams
    35. Test for ohm meter checking on electric dryers with no heat
    36. Taking apart an Duet or HE3 dryer for a belt change
    37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
    38. Timers and some common Auto dry troubles and solutions
    39. What is a grounded element?
    40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
    May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
    I have a whirlpool/kenmore plus range that came with our house when we purchased it. Former owners did not leave a manual for it. The numbers on it are 95779890 and serial RJ3516457. I wanted to "auto...
    The E1- F5 error is a door lock error.
    The control (TIMER) has likely failed in this instance - BUT...
    Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
    You should disconnect power again for 15 seconds and reconnect and see if that helps.
    If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
    Sometimes these work, but if the control has failed it won't make any difference.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$TERGD
    Feb 26, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Door handle is loose
    If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
    Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Open Questions:
    Dryers Logo
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
