Question about Bosch Computers & Internet
For the last couple cycles, my Bosch has had water remaining in the bottom of the machine. I cleaned the filter. Do you know what is causing this problem and what I can do to eliminate it?
Model SHE37AR56UC/07 FD920400375 Thank you for your assistance. Toni
    Habit-Forming:
  • 158 Answers
Here are some suggestions:
http://removeandreplace.com/2015/05/22/water-in-bottom-of-dishwasher-how-to-fix/
Posted on May 03, 2017
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
Sep 13, 2017 | Bosch Logixx WFT 2806 Front Load...
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
Bosch Excel 1200 washing machine stops at spin cycle, doesn't seem to be draining properly. If I open front drainage hatch to let water out the machine will start its spin cycle. Happening every wash...
Your filter will be clogged, causing the empty pump not to drain in time (usually they get about 8 minutes and fault out). If the picture I have of your machine is correct, there is a small door at the bottom of the machine on the right. Open the door, unscrew the filter, clean and replace and all should be well. NOTE: It's worth tipping the machine back by 45 degrees when you do this so any water left in the machine doesn't pour out, but having a couple of towels to hand would still be a good idea.
Please add a comment if the above has not fixed your problem and I will try to help further
Aug 23, 2011 | Bosch Washing Machines
Upon selecting a wash cycle and closing the door the machine starts normally (heating water stage) but never clicks to allow water in and wash the dishes. Fails to advance to the wash cycle and just runs...
Not knowing the make or if the machine is logic controlled, it’s very hard to diagnose. If it’s a logic controlled machine, my guess is the board is bad.
Jan 27, 2018 | Bosch SHV46C03 Built-in Dishwasher
A LOT of water remaining in the drum after cycle
I suspect that the filter wants cleaning.
This should be located at bottom front right of washer.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water remaining in the drum after cycle
Sounds like the filter needs to be cleaned
This is located at the bottom front right of washer behind drop down cover or flap.
Unscrew anti-clockwise to remove and clean.
Jan 15, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My Bosch shx46A05UC no longer will drain.....it
I ran into the SAME problem with my Bosch SHX46A06UC /21. The problem ultimately ended up being a clog in the air gap vent, (meaning, SOMEBODY ran the dishwasher without the bottom filter being in place or not in place properly). Remove the air gap cover and upper surface nut to drop the air gap vent into the area under the sink. Disconnect the hoses from the air gap vent filter (placing a bucket under the hose from the dishwasher). Run the drain cycle on the dishwasher. The washer should drain into the bucket and let you know that your pump works and that there are no clogs or kinks in the drain hose. (This will also remove the clog if so). The air gap vent's smaller hose connection is MOST LIKELY where your clog is. Look at the upper end of the air gap vent. You'll see a couple of clips on opposite sides of each other, that hold the air vent cap in place. Using a small screwdriver, (or your hands if you can), depress the clips (or one at a time) to get to the point where you can pull the vent cap off the filter. Either use water or a thin, long blade screwdriver to force any objects out of the filter. You should now have full flow through both branches of the filter. Using water and a rag, clean the vent cap and filter. Mount the air gap vent filter back onto the sink. Reconnect the hoses and remove the dishwasher's internal filter(s) and clean them as well while you're at it, making sure to remove any debris that might remain underneath the filter and has the chance of clogging the unit again.
Run the washer again to test. You should be good!
Cheers!
Oct 13, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Oct 13, 2008 | Bosch Dishwashers
Computers & Internet Logo
49 people viewed this question
Top Bosch Computers & Internet Experts
RudeRude
ray gallant
Brett Duxbury
Brett Duxbury
Are you a Bosch Computer and Internet Expert? Answer questions, earn points and help others
