Question about Dehumidifiers
Hydraulic and warning light stays on . bucket work 2008 272c cat
Bucket just wont work.2008 272c cat
2 Suggested Answers
  • 253 Answers
SOURCE: Dehumidifier stopped working because "water bucket full" indicator light stays on, although there is no water in bucket.
In the water bucket is a float assm. scale forms on the assm. and causes it to stick. Remove the float assm. and carefully remove the scale. Should start working again once done. If not you may have to replace it.
Posted on Mar 11, 2013
Electrolux EXD15DN3W dehumidifier has power to unit, but wont start operation? Display is off, on button doesnt respond, but LEDs light and beeps when bucket is removed. Any advice much appreciated.
The bucket interlock may be defective. It works correctly to signal when the bucket is removed but doesn't signal the power switch that the bucket is in place.
Nov 23, 2016 | Dehumidifiers
The warning light is flashing and the dehumidifier won't work. Any advice x
empty the water collection bucket ??
or if it was just empty'd then reseat the collection bucket its not far enough in
Apr 04, 2015 | Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
Mar 11, 2013 | Dehumidifiers
The full light stays on, and now it wont collect moisture how do I reset my dehumidifier so that it will continue to work effeciently??
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Sep 10, 2011 | Soleus CFM-40 Dehumidifier
The "full bucket" light is blinking- and the
When the Bucket Full Light is on, none of the controls (other than the On/Off) will work. If you haven't
emptied the bucket, do so. Then make sure the bucket is reinstalled properly into the holder. Failure to do this will cause the Bucket Full Light to stay ON. While you have the bucket out, check the inside of it for a float valve. It may be stick in the UP position. If so, jiggle the handle to make it return to the DOWN position.
I hope this helped you and thanks for Choosing FixYa.
Aug 12, 2011 | Kenmore 54501 Dehumidifier
I have the Delonghi DE500P and the lever that indicates the bucket is full will not stay down and therefore the bucket full light remains on and the fan will not start. when i use my finger to push this...
Replacing the switch/lever is more trouble and costly than it's worth. That's if you can find the part. I suggest, that you try reinstalling the bucket very carefully, making sure it making contact with the lever in the proper position. Lots of times, the bucket is simply not being inserted properly and it misses the switch. If that doesn't work and you want to repair it yourself. Contact Delonghi Parts Dept 800-865-6330.
Hope this helped you.
Apr 27, 2011 | DeLonghi DE500 Dehumidifier
The bucket full light stays on while it is empty. the humidity control doesn't change. the unit is not going on.
There should be a switch that is activated by a float lever that if tripped will make the bucket full light stay on, and will prevent the unit from going on.
If this light is on when the bucket is empty, maybe try to jiggle the float lever, or investigate why the switch is activated when the bucket is empty.
Good luck on this repair.
Dec 01, 2010 | LG LHD65EBL Dehumidifier
It wont stay running? The water is empty and the lights still on. Even when you shu it off and turn it back on
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Sep 01, 2010 | Danby DDR6588EE Dehumidifier
Dehumidifiers Logo
59 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
