Question about John Deere Garden
John Deere lx176 pto bolt. Please advise if metric or imperial? Also what is recommended torque setting? Purchased new belt seems abnormally tight causing bolt to loosen.
  • John Deere Master
  • 7,515 Answers
Here's the link and I'm sure you will get the solution of your problem.
Posted on May 16, 2017
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
Posted on Oct 02, 2009
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
  • 430 Answers
SOURCE: LX176 Electric Clutch Slips
The clutch is basically a big 12volt elecrto magnet. When it gets power it grabs the magnet and turns the blades. Usually they either work or they dont.
I would check the relay first. Then check for a loose wire or bad connection.
If it comes down to a failed clutch then be prepared to spend between 150 and 300 bucks. remove the deck and unplug the 2 wire connector from the clutch then remove the center bolt from the crankshaft and the clutch will slide off the end of the shaft. There will be a bracket or pin that holds the clutch and prevents it from spinning. Pay attention to how the bracket or pin is situated and be sure to reinstall the new clutch the same way.
Posted on Jan 04, 2010
Mower belt diagrams 2
on May 20, 2015 | Garden
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
I have an LT series Snapper rider with 20 hp and 44" cut. The transmission seems to be slipping. I have not checked the oil. Replacing the belt looks like a big job.
Not as some John Deere mowers I worked on lately.
I am assuming your is the Hydro version with electric pto. First set the parking brake as this remove tension on the belt.
You will need to remove the pto clutch and attention to the keys are positioned as they are one way keys. When reinstalling the PTO clutch it torqued to 55 ft lbs. To do this you need to remove the engine shroud so can block the flywheel movement.
The rest of the belt removal and replacement is fairly straight forward.
May 06, 2015 | Snapper Garden
John deere 216
Just a guess, but could the primary belt be too tight?
Jul 28, 2014 | Garden
John Deere A120 tension spring for PTO broke off and flew across yard I have the new spring can't fig out where it goes HELP>>>>
find the pulley that is loose and rotate it until the belt is tight either way, then add 2 inches on to the spring length and you should find your hole. remove belt from largest pulley that is clear and insert spring through hole and attach other end using a no 3 screw driver using slot to guide spring end into hole.
Nov 04, 2013 | John Deere Garden
What are the torque specs for belt tensioner
There no real specs for the tensioner. The bolt should be tight and the unit as a whole should be squared to the engine. If it is in anyway tilted, th eunit is coming apart and will need to be replaced. One bolt holds this unit in place. It should have adequate tension to keep the belt taunt against all the pullies. If you are dealing with a constant squeel issue, locate the writing and you should be able to read it like holding a book in your hand. If it is upside down to you, reinstall. this will take care of the squeeling 9 times out of 10. The tensioners for replacement run about $50 - $75.
Oct 23, 2010 | 2005 GMC Sierra
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Aug 10, 2009 | John Deere Mower Blade 5 each
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
