Question about GE Washing Machines
Machine fills and water circulates but agitator is not turning
    Sniper:
  • 57 Answers
This is not such a bad problem and is fairly cheap and easy to repair.
Open the lid, reach in and get hold of the agitator on each side at the bottom and pull up real hard to remove. (it can be a bear to get out at times)
Once it is out, you will see a smaller round plastic block with a 1/2 inch bolt holding it on. remove the bolt and pull this block off the shaft.
Replace the block with new and reinstall the agitator.
Problem solved.
Posted on Jul 25, 2009
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
My GE washing machine keeps over filling, flooding the room if we don't stop it. Where is the mechanism that measures and turns of water?
If the machine starts to agitate and the water does not shut off replace the water inlet valve. Now if the machine fills and does not agitate,then clean the pressure sensor tubing and the line coming off the tub. Hope this helps Tim
Mar 02, 2011 | Dryers
Turn washer on, only get a buzzing sound. No water fill, rotation of agitator, nothing
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Nov 26, 2010 | Whirlpool LSQ9600L Top Load Washer
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Lint from washing machine
Fill the tub to the bottom of the agitator with hot water and add 1/2 to 1 gal of white vinager and let it sit for a few hours. Spin out the water and run thru a light load without clothes. When you are running a load lift the lid and observe the clothes movement, The items should be circulating from top to bottom. If they are just wiggling around it is overloaded and the clothes do not have room to move. This wears on the fabric creating lint. The agitator is for the water not the clothes contrary to popular belief. The clothes are actually washed with the water movement not beaten by the agitator.
Eric
Jul 02, 2009 | Washing Machines
I have a Admiral washer that fills with water but won't agitate
turn on your washer start programme while it is filling turn of power point if water still enters mchine you have a faulty water valve.if water stops there is a problem with the water level switch or hose that connects from outer bowl to pressure switch maybe perished or split.hope this helps you.
Mar 25, 2009 | Washing Machines
Kenmore washing machine won't stop filling with water
yes the water level switch controles this does the machine quit filling when you turn it off if so eather the water level switch is bad or the rubber hos attached to it has come off
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
