Question about Garden
Hi can you supply a throttle cable for this saw,the cable is 460 mm long and has a small and large fitting on ither end thank you Iain macdonald
  • 45 Answers
SOURCE: throttle cable
This advice is not model specific, but normally you would remove the air filter and access it that way.
Usually the actual fitting of the cable to the carburettor is pretty fiddly; sometimes it is easier to remove the carb, to do it.
Posted on Sep 28, 2008
PABLOCSA
  • 1124 Answers
SOURCE: network cable wire too large to fit laptop connection
If your laptop is too old probably does not have a network card built in. In that case you need a PCMCIA network card and PCMCIA slot available in your computer.
You can get one here:
http://cgi.ebay.com/LAPTOP-PCMCIA-Network-Card-10-100-Ideal-for-Old-Laptop_W0QQitemZ280106314967QQihZ018QQcategoryZ45000QQcmdZViewItemQQ_trksidZp1742.m153.l1262
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Posted on Oct 18, 2008
SOURCE: Advise on fitting throttle cable
i have a xt 125 x super moto it keeps leaking fuel from the over flow y is that
Posted on Jan 31, 2009
  • 136 Answers
SOURCE: Hi, the digital HD cable signal supplied image
If you are using dishnetwork there is a button that changes the "zoom" on screen...there are 3 settings. The button on the remote says "format"
Posted on Jul 08, 2009
nedkelly900
  • 345 Answers
SOURCE: I have taken the cables off of the throttle, am
its just a bit tricky to get it all lined up, make sure the cables are in correctly first, then put the bottom half of the housing on first, making sure it rests on the handlebars, then place the top half of the housing on, press together with your hand first, wiggle it around a bit till it looks right , then put the screws in.
Posted on May 24, 2010
Which port do I add Fremont the small one or the large one on my 1998 Fleetwood Bounder with a ford 460
It will be the small fitting, the charge fitting on the hose should only fit the small one. Large fitting is the liquid line (discharge), small fitting usually on the larger a/c line, is the suction port.
Oct 11, 2017 | Ford Cars & Trucks
Tip
Repair/service cables on your motorcycle
Hi, try this trick,
Disconect your cables at the top,
Take a small plastic, zip lock bag and cut off the corner.
Place the bag over the end of each cable and tape it to the cable OUTER.
(Not the cable wire inner).
Put some light lubricating oil (sewing machine oil), in the bag and zip it up and leave for 10-15 minuites.
Refit and adjust the cable freeplay (2 mm) for clutch and brake cables(where applicable), and 1-2mm for throttle cables.
Andrew Porrelli
on Dec 05, 2009 | Motorcycles
My yardman he 4160 starter solinod wires are not connected there are 2 red thick cables and 2 thin cables can anyone help
One large cable comes from the battery and goes on one large post of the solenoid.
The other large wire goes to the starter and goes on the second large post on the solenoid.
It does not matter which post you choose.
The small wires ... if they have large ends that would fit the large posts, will go on the battery cable side of the solenoid.
The small wires ... if they have small ends, and your solenoid has two small posts, should be installed on them. Again, it does not matter which post, install one on each.
Jan 22, 2017 | Garden
How do I connect throttle cable to throttle trigger?
Search for online manual, that has the diagram, showing the location the end of throttle cable at the trigger. You will have to take apart the handle assembly, to access the cable and trigger.
Nov 05, 2015 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
The 35mm strips won,t fit in my holder how should I be inserting them in the holder
The holder that takes 35 mm negative strips on one side and 4, 35 mm slides on the other has a plastic frame that holds the 35 mm film in place. To load film you have to first remove that frame by putting your finger in the opening by the large "A" and popping that end up. The frame fits in only one direction and must be clipped back in by first engaging the two small fingers into openings at the end opposite to the "A" and the lowering the retainer down snapping the 3 sets of 3 clips as you work toward the "A".
Oct 11, 2014 | Epson Perfection V500 Flatbed Scanner
My saw runs good at idle and mid rang but when I stick it into a large limb and try to cut it bogs down and will die if I don't let go of the throttle. It acts as if it is starving for fuel. I tried to...
I have had to change a few fuel tank breathers on the 455 and 460 saws, when it starts to die try to slacken off the fuel filler cap, if it picks up again it is a brather issue, the breather is under the starter cover at the top right hand corner.
Sep 25, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
I replaced fuel and carb lines on my Poulan 2450 chain saw. I cannot seem to find the correct path/attachment for the throttle connection. Parts diagrams do not show this. Can someone provide a diagram...
It is quite difficult to explain exactly how it fits, the cable always looks too long and has to curl around on itself back to the trigger, the picture shows quite well how it goes, the end of the cable with a dog leg in it goes to the carb, as far as i remember it goes to the upper hole in the carb spindle, just push it into the hole and turn through 90%, the other end fits into the throttle trigger.adw1_9.jpg
Sep 10, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hi, I have a 1998 Ford Escort SE with 2.0
The large end should fit the rubber grommet, so it goes down. The small diameter end should connect to the vacuum line.
Aug 02, 2011 | 1998 Ford Escort
I have a new hasky 460 rancher stalls when given
If it stumbles at full throttle, the fast (high) idle screw is set too rich. Using your owner's manual, locate the high idle adjustment and back it off in very very small increments. Do this until the saw will run wide open without stumbling.
Jun 06, 2010 | Husqvarna 20" 60cc Rancher Chain Saw 460
Throttle cable
Sep 26, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
