My problem is the reverse dvd to hdd - Televison & Video
How do I record from DVD to HDD
DVD player AV out to HDD AV in RCA cable red white yellow
HDD input source has to be AV in you may have to set up a timed program chanel to av in av1 or av2
you may not be able to do this due to copyright embedded signals being detected by the HDD
Oct 17, 2016 | Toshiba RDXV60KB DVD HDD VHS Recorder
How to replace hdd on Sony RDR-HXD860 DVD Recorder/HDD Recorder?
The HDD must order from Sony It can not replace with the computer HDD.
May 04, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
LG RH2T80 HDD/DVD recorder dvd tray won't shut we have turned off the power and at the power point but it still won't shut. It sounds like something is locking or jaming. It goes a 1/3 of the way...
This is a common problem on this model LG RH2Txxx DVD Recorder unit.
Source and install a new DVD player/burner unit - cost approx $120.
Avail from :-
Easy to self instal with basic repair knowledge (+ philips screwdriver).
Remove top cover screws and cover,
Unclip front plastic front cover, roll out of way,
Remove 4 mount screws of DVD player/burner unit,
Unplug ribbon cable and DC power connection to DVD unit.
Install new unit by reverse of above procedure.
Jun 04, 2011 | LG DR787T DVD Recorder
How to remove dvd drive for Westinghouse LTV-32w4 HDC 32.02 in. HDTV LCD TV/DVD Combo
First you would have to get a service manual, this shows you all you need to know about the unit. Without it, it is very difficult to even remove the case. but once inside, it is basically a simple task, to find the drive, remove the fastenings, and the Cable, obtain an EXACT replacement HDD, and reverse the procedure, it may pay to format the HDD first, FAT32, I believe, although your manual will be more specific.
Jun 18, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No sound output on highlander dvd recorder/hdd(80g). We did have for nearly a year, but a month ago sound output stopped. ie. we can burn from hdd to dvd & play in another machine & it has sound -...
Ive just had the same thing happen to my highlander dvd/hdd 160g.
Mine lasted just over a year and I have lost the sound as well. It worked perfectly and No problems until sound suddenly disappeared
Nov 19, 2009 | Televison & Video
The dvd recorder and it hdd can't record since hdd full
Miss Fouzia Morocco
pls try to format all HDD first backup ur data by connecting the dvd recorder to pc then format ur hdd it will help lemme know
Feb 20, 2009 | Funai PY90DG DVD Recorder
Rec from hdd to disc
Only use one of the disc types that is listed in the manual that they have actually tested on unit. If the HDD recordings were made in HQ mode, then you will only be able to fit a one-hour or less recording on a DVD. You cannot reverse this at this point. For future HDD recordings, set the record mode to 4hr or higher.
Jul 20, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Replacing the HDD
before you replace your hdd ,,
step1. format the new hdd on the pc FAT system
step 2 . set the player 2 default set then replace the hdd..
reply this post when not work
Apr 20, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Televison & Video Logo
Top Televison & Video Experts
