Question about Sewing Machines
Every time I press the peddle I get an E1 code n the needle won't move
  • Jimmie Sill May 03, 2017
    Hi Joann pittman, I want to help you with your question, but I need more information from you. I need to know the type of machine?
  • Sewing Machines Master
  • 11,769 Answers
Search for:
Make Model E1 error
Posted on May 03, 2017
Needle does not move up and down manually or when peddle is engaged. You hear motor run, but needle doesn't react.
sounds if you have cotton or fabric jammed around shuttle Hook casing or you have knocked the hook timing so far out that the needle is jamming against the hook assembly case. it sounds as if the machine needs to go in to have a complete check out. Have a look at some other answers I have given on sewing machines and how to retime them if you wish to give it a try to save yourself money and time.
good luck
Mar 16, 2015 | Sewing Machines
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Apr 14, 2012 | Singer Sewing Machines
White Classic 312 - I turned on machine, reloaded bobbin and put it back in. Threaded needle, tighted needle arm after threading bobbin and pushed on peddle to start sewing. The machine locked up,...
Bake cookies. This is why you never paid attn when Mom tried to teach you in 1977, and why sewers are on a higher mental plane than yourself, Pammy.
Aug 12, 2011 | White Sewing 312 FS
I was sewing everything was fine. When I changed to zig zag it also worked but, when I switched to straight sewing and pressed the foot peddle the machine began to make a beeping sound and it won't go...
If the needle was on the down position when you switched stiches, this could have caused the problem. Raise the needle completely, power the machine off for 30 seconds, then power back on... Did that fix it?
Jun 22, 2011 | Singer 7436 - INGENUITY
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
The needle will not move up and down while pressing the peddle, and the knob feels tight when i turn it to either put the needle up or down.
This sounds like it needs lubrication, especially on the top shaft bearing. These machines are a pain to lubricate properly, as it takes longer to remove the plastic outer casings, than it does to fix the problem.
Oct 13, 2009 | Brother XL-2230 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
