Question about Seiki Televison & Video
I have a 40 inch Seiki I parred it with a remote can turn off/on TV have a good source for cable the box is good but it has blue screen, no signal and HDMI 1 in the right corner
shadowarrior
  • 43 Answers
SOURCE: HDMI has been taken over by 'DVI' after pluging in P.C
does selecting DVI, operates the HDMI mode?
I would recheck all my connections just in case, try new batteries on the remote, try operating the TV via the controls on the panel itself.
If none of this works, would suggest calling in the TV's customer care.
Posted on Sep 08, 2009
  • 50 Answers
SOURCE: "No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
Posted on Apr 27, 2010
SOURCE: Hi. I have a
I am having the same problem. . . did you get it fixed?
Posted on Feb 08, 2011
gopakumarg43
  • 73647 Answers
SOURCE: Setting Signal Source
Please refer the user manual to this TV for details. It sounds that there is a problem to the main system control memory IC to your TV. If so, it might have to be replaced. Contact any service technician.
Gopakumar Gopalan Google
Posted on Feb 22, 2014
daytoncom93026
  • 395 Answers
SOURCE: Cosby 40 inch tv, when I push Direct TV remote to turn on the television a small box with HDMI 1 THEN DVD 1 comes up. No picture and screen says : no signal
HDMI 1 is the DVD. If you want the Sat. go to the ports on the TV, look for HDMI 1 and pull the DVD line off. Replace with the line to the Sat TV equipment. Move the DVD to another HDMI port of your choosing.
Posted on Jun 08, 2015
My seiki tv got turned on to hdmi1 mode. How do I turn it off. I don't have an hd tv. The screen is blue and it says hdmi1 at the top and no signal.
you need to press source on the remote. That will let you choose what signal to use. TV, hdmi1, hdmi2, and more options will show
Oct 23, 2016 | Seiki Televison & Video
SEIKI SE50FY28 !! Tv powers on to a blue light but has no picture !!
I would try the TV inputs. Tv/Video or the Source button on your tv remote. Select each input to see if picture comes on. If you have checked all cables and Inputs, I would check the wire from the TV to the cable box.
Jul 30, 2016 | Seiki Televison & Video
Seiki TV has NO SIGNAL message. I changed the main board but that didn't fix it. Light goes from red to blue when I turn it on. Sometimes after about a half hour I'll get signal but sometimes it'll...
Do you have cable ,satellite? Does the no signal come up on all inputs?
Reset cable or satllite box by unplugging from the wall. If HDMI is being used unplug and replug HDMI at d both ends.
Dec 29, 2014 | Seiki Televison & Video
My tv won't work after I shut it off using the remote throught the cable box
You need to turn on the cable box again. Make sure to select the right source again for your tv.
Jan 11, 2014 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
No signal on tv
Your Samsung has an Input Source button on the remote. If you are getting a "No Signal" message, you either have no cable, dish, antenna, or HDMI input to the television or have the wrong source selected. With the television turned on and/or a cable box, dish etc turned on, select all of your sources until a picture appears.
Jan 17, 2012 | Samsung 403T 40" LCD Monitor
Rca 20F514TD blue screen
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 05, 2009 | RCA 20F514TD 20" TV
Advent Tv on direct tv with snow showing on screen
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Jul 22, 2009 | Recoton Advent Advent HT3251A TV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Tv does not work powers on and off
Jan 07, 2009 | Spectroniq PLTV-42HW68 42 in. LCD TV
No picture, blue screen only
Good Day;
It sounds like you have a lack of signal; 1. reset TV by unplugging TV & signal sources from wall for at least 5 minutes then plug back in, 2. Turn all eguipment on such as cable box, dvd & etc, then change the inputs from your TV's remote, if still no pix,only blue.
Good Luck.
May 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
