Question about Craftsman Garden
I have a craftsman mini tiller and it's idoling at full throttle. I can't figure out why?
    Top Expert:
  • Craftsman Master
  • 47,657 Answers
Governor control not connected to carby
Posted on May 03, 2017
Just stopped running, changed fuel tank,spark gapped at .025 , air filter, added new fuel still won't throttle up and is hard to start. What's next?
If you have a fuel bowl on the bottom of carb remove the cup and clean well and clean the fuel jet as well. If its even partly plugged The engine will not run right.
Aug 04, 2015 | Craftsman 4-Cycle Mini Tiller
How do you change the primer bulb in a craftsman mini tiller?
some primer bulbs come as an assembly and have two clips that snap into the housing others are bolted in with 2 screws if so remove the screws and make sure to take what is left of bulb to match up the new one
Oct 15, 2012 | Craftsman 2-Cycle Mini Tiller
I have a craftman 4 cycle mini tiller, running to slow. need to run at a faster speed. do not where to adjust.
If the carb has the "fixed" throttle control. Find the governor control lever with the small, long coiled spring attatched to it in the middle. It may be hooked to a metal tab that is on the back carburetor bolt. Bend the tab to your left to increase set speed or to the right (towards governor lever) to decrease.
Sep 05, 2011 | Craftsman Gas Mini - Tiller/Edger
I have a sears mini tiller,2cycle and i can get it to start,but when i try to throttle it up it dies
try it with the choke on, if this helps then clean the carb and check fuel filter if it has one,if all that doesnt help then open up low speed jet and try that, another cause could be muffler screen plugged w/carbon, remove and clean
Apr 13, 2011 | Craftsman Gas Mini - Tiller/Edger
I own a 2 cycle mini tiller craftsman and I need a manual for it. I want to tune up tiller it's blowing smoke.
Manuals for many Craftsman tools are available here: http://www.managemylife.com/mmh/owner_manuals . Lots of tillers are listed just by searching for Craftsman tiller. If you can find the model number (usually on a plaque on the housing of the tiller), you can narrow down the list greatly.
I hope this helps.
Mar 31, 2011 | Mtd Craftsman 4Cycle Mini Tiller
I have a Model 29270 REV B00 Craftsman 4 cycle mini-tiller. Can't find a spark plug or air filter. Appreciate some direction.
Craftsman part numbers will help on this search. Typically 3 digits separated by a '.' such as 345.45687
If you can find these, please re-post the question. :)
Sep 25, 2010 | Craftsman Gas Mini - Tiller/Edger
Tines run slow/stop even when engine is at full throttle
What is the task you are doing with the tiller? There are some uses where the tiller will stop.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Craftsman mini tiller
Craftsman mini tiller. Are you selling this unit, giving it away or what. Your information is somewhat meager to say the least.
May 28, 2010 | Craftsman Gas Mini - Tiller/Edger
Craftsman mini tiller starts good but will not idle nor run fast
i'm having the same problem. cleaned carb but didn't help. I found that if I spray starting fluid on the gasket between the carb and the motor it speeds up. I'm going to try to find a new gasket, I can't tighten it anymore.
Good luck
Jun 30, 2009 | Craftsman Gas Mini - Tiller/Edger
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
