Question about Briggs Garden
I took off gas tank on my Briggs tiller to clean it out. cant get the wire linkage on
    Genius:
  • 2,653 Answers
Take the tank off again, fit the linkage by turning the tank , then refit the tank.
Posted on May 03, 2017
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
Why won't my rotor tiller stay running after starting Its a briggs and stratton
95% of run ability problems are carb related. It needs to be disassembled and cleaned. Do you leave gas in it at the end of season,if yes always drain the tank and let it run till it stops next time before storage. Good luck
Jul 08, 2014 | Husqvarna McCulloch Garden Tiller, 5hp...
5hp Briggs engine on craftsman snow blower won't stay running
Remove the nut that holds the float bowl on and clean the hole on the side and the hole that goes down the center of the bolt.
Jan 05, 2014 | Briggs & Stratton Snowblower Snow Blower...
Engine surgings after running 1hr
You're on the right track its definitely fuel starvation. Try cleaning the fuel tank breather (it's probably in the tank filler cap). This allows air in to the tank as the fuel is used, if it's blocked you get a partial vacuum in the tank and the fuel wont come out.
Jan 02, 2014 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Throttle linkage diagram
maybe someone took off the linkage cable what you need here is
to find a schematic of your unit and that should tell you where everything goes on the unit .you should be able to download a
schematic from the web!
Nov 09, 2013 | Garden
Gas tank leak
The gas tank would go with the engine. Find the engine number (Briggs & Stratton?, Kohler? ) You can order it online from Briggs & Stratton parts, or like Jack's small engine, or your local mower parts supply. Common poblem with these plastic tanks.
Jul 19, 2010 | Troy-Bilt Pony Garden Tiller
Pony Garden Tiller: does a tiller with a briggs and straton engine nee...
The pony tiller with a Briggs and Stratton engine only uses gas do NOT mix oil with the gas.
Frank
May 18, 2010 | Troy-Bilt Pony Garden Tiller
Son's dog ate wiring off of tiller motor
Using your engine's serial number you should be able to access a wiring diagram via briggs and stratton's website but the green is a ground most likely. There should be a stop switch connector that plugs into a wire that usually connects somewhere under the gas tank and the green is most likely your ground that should ground via a flange bolt, this is the stop switch terminal.
Apr 15, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
I need a diagram for the carburetor linkage on a yard machine tiller model number 216-430 or a diagram linkage on a briggs and stratton engine model no. 135202
go to partstree.com and get a diagram for this.
hope this helps you.let me know.if you cant find it ill get you one ok.let me know
Jul 21, 2009 | Garden
Statesman Tiller
without knowing if its a briggs and straton or tecumseh engine ( I assume Briggs) the carb is where the throttle and gas line connect to. carb will need to be rebuilt most likely and tank will have to be removed to be cleaned. you can email me and I could do it for you I am in wisconsin kerryjonjon at yahoo.com I am the most reasonable in this area. I could do carb and tank if you want.
Jul 11, 2009 | Garden
Garden Logo
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
