Question about Garden
Why does my left hand drive wheel on my Scagg cheetah mower not go
5 Suggested Answers
jdlipscomb41
  • 157 Answers
SOURCE: Self-propelled lawn mower wheel removal
no ht they should both be the same try some wd40 and let her soak awhile. jd from la
Posted on Sep 19, 2009
Testimonial: "Ok, I'll keep trying. Thanks for the comeback. HT"
  • 773 Answers
SOURCE: I have the Cub Cadet
the drive splines on the inside of the wheel are chewed up. It happens some times. It is more prone to happen when you are mowing on lots of hills. The drive gear has nothing to grab onto to turn the wheel.
You can order a new wheel just about anywhere. I recommend going to Lowe's because they can get MTD parts fairly quickly. Just bring the the model and serial number. Look on the serial tag, there is also a long model number which usually starts with 2 numbers and a letter. Bring that. I recommend replacing both wheels if you are going to do one because if the one is worn out, then the other is most likely on the same path and you will eventually replace it anyway.
Posted on Aug 10, 2011
Terry Corrow
  • 10875 Answers
SOURCE: 61 inch cut Scagg turf Tiger Blade removal. Is the top nut left hand or right hand thread?
righty tighty,,lefty loosy
Posted on May 06, 2015
  • 39252 Answers
SOURCE: belt diagram for 61 inch scagg mower deck
Request the diagram directly from Scagg.
Posted on Jun 20, 2017
Belt diagram for 61 inch scagg mower deck
Jun 20, 2017 | Garden
Is it safe to dive a 580 grandmaster lawn mower with one hand
no
if you hit a pot hole , stump or obstruction it will jerk the wheel out of one hand and possibly roll over
safety first . riding a lawn mower is the same as driving a car with the added risk of spinning blades underneath
two hand s on the wheel of a car --two hands on the wheel of a mower
Jun 07, 2016 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Driver windows xp
browse over to http://www.seagate.com/internal-hard-drives/enterprise-hard-drives/hdd/cheetah-15k/ and select the options on the right hand side that match your drive. That will give you the model number.
Then go to https://apps1.seagate.com/downloads/request.html and fill in the model and serial numbers to get the right software drivers.
Jan 08, 2014 | Seagate Cheetah (ST3146807LW) 146 GB SCSI...
Scagg freedom slowed down and will not drive
Is this problem on both side are just one side?
Nov 15, 2013 | Scag SFZ61-730FS Freedom Z Zero Turn
Craftsman 33 wheels lock
look for a bent linkage rod from the impact moving the engaugment spot
Aug 17, 2012 | Craftsman 10.5 Hp 33" Commercial Cutting...
Do you have anyone who knows about th Super Z Scagg lawn mower?
Yes, there are alot of experts that knows about Super Z Scagg lawn mower, Gurus like goeffreyh, hotchevy1965, BCAS1298 are good expert in this area.
Take care.
Aug 19, 2010 | Sport & Outdoor - Others
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sep 18, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
