Question about Pool Pump Pool & Spa
My utilitech 1.5 hp pool pump keeps tripping the breaker. What is wrong?
It runs for a short time and then it trips the breaker. I prime it and it starts back up only to stop again. We opened our pool a week ago and it was running good and then this started and it is doing it more and more. I backwash and don't know what else to do.
    Top Expert:
  • Pool Pump Master
  • 7,401 Answers
Bad motor overheating replace whole pump
Posted on Nov 23, 2017
    Top Expert:
  • 12,744 Answers
Check and test pump motor possible failing but try lubing bearings and check pump impellers for debris
Posted on May 03, 2017
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Pool pump turned off when turned back on popped and smoked
Ouch! Never run a pump that is leaking badly. It sounds like the seal or the housing gasket didn't set right when the motor was changed out.
The short story is you need to replace the motor again. The thermal overload and the breaker kept your house from catching on fire. Get qualified help to install next time. People consistently underestimate the amount of damage that pool equipment can cause when not done correctly. Better luck with the next one!
Jul 03, 2013 | Pool & Spa
Pool time switches pool on, but off does not trip off, and can't do it manual. When I push it on off, the pool pump tries to stop but continutes running. Have to use breaker box.
Model number of timer is not known.
Is this new installation? Or installation that worked before and recently stopped working?
If the manual override lever on timer does not turn Load on-off, then 1) wiring is wrong or 2) timer has gone bad or 3) pump has a short.
I suspect a short since you say the pump 'tries to stop running.'
Copy following links for troubleshoot walk-thru, and correct wiring:
Jun 28, 2012 | Intermatic T104 24h 208-277v Mechanical...
Hoover HD73M dishwasher keeps tripping the circuit breaker
Have condensation in the electrical connector .It is grounding .Call an electrician to repair ground and short circuit.
May 10, 2012 | Hoover 24 in. HD73M Free-standing...
The pool timer goes on, the hayward 2 HP pool pump turns on and then causes the circut breaker to pop. After two, three resets, it starts to work. This problem started a week agao. The pump is 9 years old.
could have a bad run capacitor or a start capacitor . search your area for your local pool pump motor repair guy with free testing, 9 years old that motor needs to be rebuilt.. i charge 85.00 to rebuild a 2hpincludes a free shaft seal.. remember to prime the pump with water after a repair !! best of luck .. oh breakers become week after amount of time time .. and ask the repair guy if this is the right size pump for you pool.. 9 out of 10 times its way too big !.. jay longwood florida
Sep 08, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
The circuit breaker trips as soon as the circulation pump tries to start on initial priming. I think that the soft start on the pump has stopped working is this likely and can it be repaired without...
you might have a weak breaker. or a dirty start switch and or a bad capacitor.; search you area for your local pool pump motor repair guy with free testing.. a repair to the motor should cost 20-85$.. remember to prime the pump after a repair.. jay Florida . hit the yes if i was of help
Aug 29, 2011 | Emerson Pool & Spa
Motor will not come on everyday. comes on some days and then others, you have to start it manually. Replaced control panel 6 weeks ago and worked fine, now same problem again. Motor runs at lowest speed...
FIRST: When you shut the breaker off and then back on was it because the breaker was "tripped" ?
SECOND: Does the motor run "hot"? Feel the outside of the motor casing when its running to check. ****becareful - it may be really hot****
As soon as you get back to me with the information I can tell you what is going on and what direction to go in. Thank's
Dec 08, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
I noticed that my the spa water level got really low. My pool pump is has stopped working. The breaker was tripped and I reset and it tripped again. Is the pump fried?
Probably the heater. Turn the heat off and try it. There should be a flow switch to prove pump is on before the heater works, but sometimes if you're running low, it will work intermittent. Do you know how it got low? evaporation? Is the pump leaking? If the pump is leaking, and has leaked for awhile it may have shorted out the motor. While running the pump low on water will damage the mechanical seal that keeps the water in the pump, it should not affect the motor itself.
Oct 19, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Pool & Spa Logo
48 people viewed this question
Top Pool Pump Pool & Spa Experts
Lawrence Oravetz
john h
Steve Buck
Level 1 Expert
Are you a Pool Pump Pool and Spa Expert? Answer questions, earn points and help others
