Question about Garden
How do i remove mower deck on a Husqavana lawn tractor
Peuhayd
  • 11 Answers
SOURCE: removing tractor deck to change belt and blades?
if i am thinking of the right model you may be able to get away with first taking off the blade, then to remove the deck should be a number of bolts under the chassis and on top of the deck where it meets the frame... you can get your parts here if your having trouble finding them
 http://www.ordertree.com/modelinfo/MTD/13A1674G401-%281997%29/62.13A1674G401-%281997%29.1.1.1.html
Posted on Sep 06, 2008
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 229 Answers
SOURCE: MOWER DECK BELT ROUTE FOR LA175 JOHN DEERE LAWN
you can try johndeere.com you should be able to find it there.
Posted on Oct 20, 2009
agent91
  • 2100 Answers
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
Posted on Jun 10, 2010
  • 41 Answers
SOURCE: Ineed to get the belt routing diagrams for the
GO TO INTERNATIONAL PARTS SITE, ENTER TRACTOR MODEL, SELECT PROPER DECK AND THE PARTS LIST HAS A BELT DIAGRAM BUILT IN. IF YOU HAVE AN INTERNATIONAL BELT FOR IT BEAT A PATH TO A BEARING COMPANY TO ORDER THE SAME OR BETTER BELT FOR LESS THAN 1/4 THE IHC COST.
Posted on Jul 07, 2010
How do I remove mower deck?
I've added two links that should be beneficial to you to help you remove your mower deck, however, I am not sure what kind of mower you have since you did not specify. Hopefully these will help you, if not, let me know what kind of mower you have and hopefully I will be able to be of assistance!
Good Luck!
How to Remove and Install the Deck on Simplicity Broadmoor Lawn Tractor
How to Remove and Replace the Deck on Toro TimeCutter Zero Turn
Oct 10, 2015 | Garden
Craftsman Lawn tractor 20 hp twin clynder briggs with a 42 inch deck I need a model number the plate is unreadable
Maybe this will help.The mower deck part # 165892. Mower Deck Assembly 42" I not sure of the model # . I also don't know your tractor's model # either. This part # for the 42" mower deck,is installed on a 18.5 HP Craftsman Lawn Tractor. I believe there isn't any difference between a model !8.5 HP and a model 20.0 HP, tractor when it comes to a mower deck. B.Locke
Sep 14, 2015 | Craftsman Garden
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
How do i replace a blade that had fallen off. 42 inch tractor. The main problem is how to get underneath the tractor?
To replace blades, belts, sharpen blades, etc. one must remove what is called the cutting deck from the tractor.
Once the deck is off the tractor, pull it out, turn it over and you can work on the blades.
Gary
Jul 10, 2011 | Ariens 42" Riding Lawn Mower Blade ...
How do i take out the mandrile
remove the blade, remove the deck from the tractor, remove pulley covers, remove the deck belt, remove the bolts holding mandrel to deck, remove the mandrel. reinstall in reverse order.
Jun 23, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a model 13AH762F752 MTD Lawn Tractor on the front the bar that holds up the mower deck which way should it go in.? If you are looking at the tractor from the front R or L
if the mower deck is on the ground under the tractor raise the front of the deck up and push the deck towards the front u ntil the tabs are lined up with the hooks on the deck..good luck
Apr 06, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
How to replace the drive belat on craftsman 917273280, 21hp, 48 in cut?
you remove shield from engine remove belt, remove deck from mower and remove pulley guards and install belt replace guards , reinstall deck, put belt on engine pulley replace guard
Jul 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you remove the mower deck from a craftsman riding lawn mower
Most of these have a cable to pull deck into gear, which has a r clip to remove ,than two rods that go from font of deck towards front axle- remove 2 R clips to drop them, and 2 more at the back of deck, un hook belt around engine pulley, than slide deck out. See how this goes. Or you my have dune it by now.
Dec 15, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
