Question about Stihl Garden
I have a fs90r trimmer stihl and I need carb and a throttle cable can you help me get the rite one and the gaskets of course
  • 2,598 Answers
Take the model and serial numbers to any Stihl dealer and they will supply.
Posted on May 03, 2017
What is Wrong With a Stihl FS90R Trimmer When The Primer Bulb Won't Fully Fill After Priming?
1) check valves inside the primer plate is sticking
2) fuel pump diaphragm is varnished and flaps are sticking to the body of the carb
3) the cost of parts and time spent are more than a new carb
4) new carbs are updated versions and have updated ethanol resistant components
** suggest a new carb, it will solve several performance issues
Feb 19, 2017 | Stihl Garden
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Stihl FS90R weedeater trigger sticks
Replace the throttle cable they bad to fray at carburetor end.
Apr 05, 2015 | Stihl Garden
Need a new wire from throttle trigger to carb
throttle cable, call a Stihl dealer. Part look-ups for Stihl and others are not available online
Aug 28, 2013 | whipper snipper stihl fs 38
Stihl FS200 repair manual
I just saw this deal on the Fs200 Stihl Brushcutter. Equipped with a Zama c1qs51 carb. Junk the carb. Go to a stihl dealer and buy a three screw chainsaw type carb with a high low and idle screw. The c1qs51 is junk.The three school carb will put an end to your worries. Of course change your fuel filter naturally. I guarantee this will fix the thing. I own an Fs200 and Fs250.
Jul 15, 2012 | Garden
I have a new Stihl FS90R Trimmer...Idles fine but dies when given gas to rev up. Tried to adjust the carb out. Did not help. I have two of these.Changed the carbs and the same thing happened. The same carb...
My nephew had a problem with his Stihl FS55R trimmer, sez it would run on high for a few then quit. Sez it restarts easy and runs on idle with no problem. I pulled carb & found fuel screen full of fine contaminant. This is the screen you see when you drop the bottom pan of the carb. (single screw does it). Reassembled and the trimmer runs on high speed w/o problems. If your primer bulb doesn't pop right back up when you punch it down, it means that the fuel can't get past that screen....
Nov 07, 2009 | Garden
Starts ok wont pick up speed
check to see if the throttle cable is hooked up to the carb. look at the back of the motor and watch as you pull the the throttle to see if the cable is hooked up. if the cable looks to be working correctly then pull the spark plug up and heat it up with a blow torch and put it back in. if the motor runs good then you need a new spark plug. if those two things do not work then you need to replace the carb diapram and gaskets.
May 18, 2009 | Yard Machines Garden
Stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
Apr 17, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
46 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
