Question about Magnavox Televison & Video
Having trouble with magnavox hdd recorder - Magnavox Televison & Video
If your Comcast box has a composite output, you'll be able to record SD shows. Use RCA composite video and audio cables between the box and the recorder. You'll have to set the box to the channel you want to record and leave it on. Then set the HDD/DVD unit to record from video input (L1 rear, L2 front) for the appropriate length of time. The manual explains this. The manual is available from Funai who built the unit with the Magnavox name: . See pages 19 and 42. If your TV and/or cable box only have a limited number of video inputs/outputs, you may need to daisy chain the composite video cables from the cable box to the DVD/HDD unit's video in. Then connect another composite cable from the DVD/HDD video out to the TV.
This Magnavox unit can only read analog (NTSC) cable video signals without a set top box. You will not be able to record a show and then watch another with the cable box.
I hope this helps.
(I know that my cable system's box has a composite video out. So it does work with most of the Comcast boxes. Many of the manuals are available here: )
Sep 25, 2014 | Televison & Video
How connect Magnavox DVDR to Comcast Cable Box ?
You'll need to use the direct input on the rrcorder from the DVR video output.Some channels won't record as they're encoded
Sep 25, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Magnavox MDR537H/F7 no power
Some surge protectors cut off all power, when they reach the surge protection limit in joules. Power strips have reset buttons to restore power. Try plugging it directly into the electrical wall socket. If it works, then purchase a new surge protector. The DVD recorder may have a internal fuse that has burned open.
Jun 03, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Magnavox MDR537H/F7 -- DEAD no power
There is usually an internal fuse in all audio/video equipment and it will normally be a 20mm glass one positioned near the power supply or somewher close on the circuit board. There may be more than one so have a good check around. Be sure to replace with the same type and rating, no sticking kitchen foil across it to short it out, this illegal and DANGEROUS.
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
Jan 22, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
How do i record a program and then watch another one, with the Magnavox H2160MW9
The unit is not a DVR capable of recording one channel and watching another. You can only watch or record one program at a time. Sorry.
Sep 22, 2010 | Magnavox H2160MW9 HDD Recorder
I have a Magnavox H2160MW9 A. It has a dubbing feature and says I can copy from HDD to DVD. But when I follow the instructions "Selected Title Dubbing", The dubbing selection is grayed out. Note that I'm...
Choose Dub on remote. Choose HDD to DVD. When you are looking at your HDD Titles, move the cursor (the highlighted box, using the left/right buttons on your remote) to the title you want to Dub. Hit the OK button on your remote. Then hit the Dubbing button on your remote. If you are ready to record, move cursor down to Start Dubbing. Choose speed, then hit OK button.
Jun 19, 2010 | Magnavox H2160MW9 HDD Recorder
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
