Question about Protron Televison & Video
No longer able to access all five of the menu options on protron 3750. setup the only option. all menu functions worked fine then for whatever reason this happened
  • 217 Answers
SOURCE: Menu Options
sound or volume can be lowered or turned off using zoom control button
Posted on Aug 31, 2007
phone crazy
  • 32 Answers
SOURCE: Codes for Magnavox TV/DVD 13" combo
try this,try going to; see if that will help
Posted on Sep 22, 2008
  • 121 Answers
SOURCE: Date/time stamp control in Menu won't allow access
In many cameras these settings depend on the shooting mode. Did you change the shooting mode? If so, return to your normal shooting mode and the function should be available again.
If this doesn't fix your problem I need to know if you have your camera's user manual. If I can find the solution in your user manual I need to know if you can read the steps in your own manual or if I need to provide you a link to read the manual online.
Posted on Jan 11, 2009
  • 8 Answers
SOURCE: access the menu options manually
Press the set's Volume (+) and (-) buttons simultaneously to activate the Menu display. Use the Channel Down button to scroll to the desired menu item, then use Volume (+) or (-) to change that item, or to activate a sub-menu if any. (If in a sub-menu, again use Channel Down to reach the desired item, then Volume (+) or (-) to change its setting or value.) When finished, press Volume (+) and (-) simultaneously as needed to "back out" of the menu.
Not all set functions can be reached this way, especially a few involving numeric entry; but this will get you started. Good luck!
Posted on May 22, 2009
  • 331 Answers
SOURCE: 1800HG DSL modem/router: Cannot access any of the setup pages.
you have to set the unit to default hold the reset button for about 30 seconds the small hole
Posted on Jul 11, 2009
Functions greyed out
Greyed Out Menu Options
Samsung ElectronicsMar 13, 2013 - Home > Setup & Installation > Greyed Out Menu Options Share on Google+ ... The menu options you have access to on many Samsung TVs ...
Antenna menu is grayed out - Forums - CNET > Forums > Samsung
CNETApr 21, 2013 - I have an HD over the air antenna going into my Samsung TV. However, the antenna as well as the Plug in Play menu is grayed out and can't be selected. Any ide... ... I think I might do 1 of the these two options. 1. Buy a new ... Samsung Support for Smart TV is terrible
Jun 11, 2015
TV Picture settings greyed out?
Sep 22, 2013
Samsung Smart TV update problems
Aug 29, 2013
Grayed-out menu settings with LN32A550
May 31, 2009
More results from
Why is some options in TV menu grayd out? - SamyGO
Dec 25, 2015 | Televison & Video
When plugging antenna in 37: protron tv do I use analog input or digital input?
An antenna is analog. Try using the setup menu for the tv to choose analog input.
Jan 18, 2015 | Protron PLTV-3750 Television
Access menu without remote on Toshiba 27AF44
You can follow the option of searching the internet for any of several suppliers of OEM replacement remotes. The problem with universal remotes is that not all functions of the OEM remote are replicated.
Dec 19, 2013 | Toshiba 27AF44 27" TV
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
Bios nonva 5600 aspire
The BIOS Setup Utility is a hardware configuration program built into your computer's BIOS (Basic Input/Output System).
Your computer is already properly configured and optimized, and you do not need to run this utility.
However,if you encounter configuration problems, you may need to run Setup.
To activate the BIOS Utility, press
during POST (when "Press <F2> to enter Setup" message is promptedon the bottom of screen).
The setup screen displays BIOS as follows:Navigating the BIOS UtilityDuring setup,all Fn function keys and power saving functions are disabled.
There are five menu options:
Main, Advanced, Security, Boot and Exit.Follow these instructions:
To choose a menu, use the cursor left/right keys (zx).
To choose a parameter, use the cursor up/down keys (wy).
To change the value of a parameter, press p or q
while you are in any of the menu options to go to the Exit menu.
In any menu, you can load default settings by pressing t
You can also press u
to save any changes made and exit the BIOS Setup Utility.
hope this helps
Aug 02, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
Why can't i optimize image?
Go to the CMS Setup menu. There are three options; Simple, Full and My Menu. You need to set the Full option to have access to all of the menu options. I think your camera is set to the Simple option which limits the available menu functions.
Nov 17, 2011 | Nikon D80 Digital Camera with 18-55mm Lens
Need to reset a VeriFone 3750 v501 to its original default state. The program password has been changed and I cannot access to update
Turn off and unplug the Verifone 3750. Wait for five seconds or so and then plug it back in. This will automatically reset the Verifone 3750 and it will reboot and restart.
Reset the shift. Resetting the shift is another reset option available for Omni. Press "Shift," then "#," followed by "1" to reset and change the shift.
Press "Shift," then "#," then "2" to stop a change and keep the shift on the current settings.
Below is your user/install manuals, it's all in there so download each copy for any time later. -
Mar 30, 2011 | VeriFone Omni 3700
ok, you press F2 or F3 to enter into the bios setup.
Oct 27, 2009 | Sony VAIO Digital Studio PCV-RX580 PC...
Power supply 3750 protron
These cicrcuits boards are no longer being manufactured. The only option at this point is to get the defective power supply repair but most service techs do not want to fix them.
I can repair it for you but you will need to remove it and send it to me.
If you require further assistance, write to
Jan 24, 2009 | Protron PLTV-3750 Television
Televison & Video Logo
29 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
