Question about Moen Plumbing
How do you tighten the handle on Moen 7594E - Moen Plumbing
    Novelist:
    Champion:
  • 227 Answers
There is a plastic button on the bell of the handle right by the base of the lever. It might be blue and red for hot and cold or it may be the same finish as the faucet. Remove the plug and tighten the allen screw. It takes a 3/32" allen key. If this doesn't tighten it adequately, you must remove the handle, and gently tighten the plastic retaining nut with an adjustable wrench or a channel lock pliers. The adj wrench is recommended over the pliers.
Posted on May 03, 2017
We have a moen 7594E. Lower water pressure than old standard Moen.
The pull out spout/spray has backflow preventers built into the hot and cold supply lines coming from the body of the faucet. The backflows have a tendency to lower the flow rate because of the additional restriction they cause.
Mar 07, 2017 | Moen Plumbing
I have a Moen Ascent kitchen faucet. The chrome handle that is attached somehow to the control valve underneath has come loose. How is the handle attached to the valve and what is the remedy?
Moen kitchen faucet handles in this series are held onto the cartridge stem with a set screw. First turn off the water supply to the faucet. You need to move the handle until you can see the small plug button that covers the set screw. This is ~3/4" from the edge of the handle. Remove the plug with a small screwdriver or other levering tool and adjust the handle if needed to get it on the cartridge stem. Then find the appropriate Allen wrench to tighten the screw. (It may be a 3/32" but this isn't always true.) To test if you have it tight, turn on the water and see if the water is easy to turn on and off. Turn off the water and replace the plug button. Then turn the water one last time.
To see a parts diagram for a couple of models of Ascent faucets, see https://www.moen.com/support/Ascent/Ascent_Chrome_onehandle_high_arc_pulldown_kitchen_faucet/S71708 or https://www.moen.com/support/Ascent/Ascent_Classic_stainless_onehandle_high_arc_pullout_kitchen_faucet/S71709CSL .
I hope this helps.
(Do not over-tighten the set screw. This could damage the cartridge or handle.)
Mar 04, 2017 | Moen Plumbing
Moen Kleo faucet. Handle loose, removed set screw to tighten but now no water pressure. (it worked fine before inspector came for house sale)
Something always seems to happen when an inspection is due. The handle tightening operation may have affected the cartridge inside. Back off the screw and water may return. If not, the cartridge may have to be replaced.
Jun 30, 2016 | Moen Plumbing
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    I have a single lever Moen faucet where the handle is very loose and there is no button on the back side that would reveal an allen key, so I cannot tell how to tighten it back up. What should I do?
    On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
    Nov 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
    HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
    There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
    Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
    I have a loose handle on my Moen two hanlde lavatory faucet and i can't find any set screw to tighten it . How to tighten the handle to the faucet stem?
    Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
    If you can't see a set screw it may have a screw in handle on top.
    May 03, 2010 | Moen & Villeta Two Handle Lavatory Faucet
    Handle is loose water flow weak
    to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
    Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    The handle is loose. It's a single lever control. The mechanism the level connects to still works fine. No leaks, but the handle is now quite wobbly, and I don't know how to tighten it. Do I pry out that...
    Remove the plastic red and blue insert or what ever color yours is under the handle in the front. Tighten the set screw with an allen wrench. Be careful not to over tighten or the screw will break off.
    Dec 27, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Own a Moen 87888 kitchen faucet. The handle has gotten wobbly. How do I fix this?
    Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
    Thanks and Please Rate jj505
    http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
    Mar 10, 2009 | Plumbing
    Plumbing Logo
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
