Question about Saeco Coffee Makers & Espresso Machines
I have a Saeco Magic Comfort + expresso machine and am looking to buy a brew group for the machine.
  • 40 Answers
SOURCE: Saeco Vienna Digital Expresso Maker - brew group will not line up to fit back into espresso machine
Could be a number of reasons. If you "hear" the brew group moving in one direction, stop and then move again, then the microswitches are o.k. If the sound of the movement is low and/or slow ( slower that normal), the CPU/power board may be bad and needs to be replace. If the movement is as before (same sound and movement) but not lining up, perhaps the brew drive motor is bad.
To remedy this situation, an authorized SAECO Service Center would have to open your machine and replace damaged components. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
  • 1089 Answers
SOURCE: Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Posted on Jan 10, 2010
  • 18 Answers
SOURCE: cannot release the brew group for, saeco
Group is stuck in mid cycle due to some obstruction. You will need to have it serviced. Though it's possible to jiggle and pull it out. The machine will not likely reset itself, preventing you from re-inserting the group. Still requires a service to manually remove obstruction and reset it.
Posted on Feb 10, 2010
  • 1089 Answers
SOURCE: Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
  • The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee’s you have made. It’s just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
Posted on May 07, 2010
espressonist
  • 1711 Answers
SOURCE: Saeco Magic Comfort Plus dumps
From your description we understand that your machines vital parts like water pump, grinder, group and gears, boiler, electronic board all are working fine since there is a final result the coffee.
The only problem you face is that due to long time use some coffee liquid have dry out layer by layer and have goggle the Teflon pipe of the plastic unions so the coffee cannot be deliver through to the coffee tap and as a result is ending in the coffee drugs drawer.
So you need to disassemble you machine and remove the Teflon pipe which is after the coffee croup and by using a thing metal wire like a paper clip or similar you can check the pipe and the plastic unions to find out where they are goggled from dry coffee. You can immerse them in boiling water from some minute so the dry coffee to dissolve and be removed completely. By this chance you can remove also the coffee group filters and also clean them with hot water.
We have here below the link with exploded parts view of your model which will help you find the parts and understand how your machine is constructed.
http://www.partsguru.com/user/E003039-ed1.pdf
Also you may now you don't have any problem but we suggest performing at least once every month de-scale so to keep your machine in perfect condition.
Also if you might need nay part replacement you can even order it from the same side in this link
Posted on Dec 11, 2010
Water leaks out under the brew group when brewing coffee
maybe you have to change the small thing which is like a pipe on the brew unit
Oct 21, 2013 | Saeco Magic Comfort Plus Espresso Machine
I have a saeco magic comfort +. It is, all of a sudden, not going thru the rinse upon set up. Then, it is not putting water thru the grinds, and, thus, pushing all grinds dry to waste, not generating...
Hi
Don't really like the rinse cycle because it waste water. If you want to rinse the brew unit just push the "scoop button" and not put any coffee in, then push the large coffee. Does the same thing but doesn't use as much water.
Dry grounds is one of my tips.
http://www.fixya.com/support/r4084157-dumping_dry_grounds_not_making_coffee
Jul 23, 2011 | Saeco Magic Comfort Plus Espresso Machine
Saeco magic comfort plus - brew unit miss??
Check the micro switch that the brew unit hit when it enters the machine. Sometimes the lever arm on the switch breaks off, and the switch will no longer work. Click the link for a picture of the micro switch.
Micro switch for saeco and gaggia machines
Jan 15, 2011 | Saeco Magic Comfort Plus Espresso Machine
Cannot release the brew group for, saeco
Feb 08, 2010 | Saeco Odea Go
Saeco magic comfort has message brew unit blocked!
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
Feb 01, 2010 | Saeco Magic Comfort 103467 Espresso...
Saeco Magic Machine does not turn on
It is probably a micro switch not getting a contact to complete the circuit. There are several of them on the machine. Take all removable pieces off and put them back on making sure they are all seated properly. ie- there are three micro switches just in the brew group service door on the right side of the machine. There is also one on the dregs box.
Jan 02, 2009 | Saeco Magic Comfort Plus Espresso Machine
Brew unit missing?
Make sure the brew unit fits in place, press the "press" button when you put in the brewunit.
Let me know if it works.
Aug 06, 2008 | Saeco Magic Comfort Plus Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
