Adding minutes Trying to add minutes but won't let me
Adding machine freezes, no buttonsvwork
Uh... Mary, d'you mean you have an adding machine which freezes, or you're trying to add a machine to an existing system, and the system freezes, or what, please?
Either way, has it always done this or what's changed, please?
Nov 06, 2017 | Office Equipment & Supplies
Adding coolant
Read your owners manual & read what the lines say
on the tank
Why are you adding?
Vehicles use no fluids
If you have to add to any fluid you have a repair to make
Mar 11, 2014 | 2007 Chrysler Pacifica Touring
Ibico 1232 adding machine won't print totals
For mine to print I have to hit either the subtotal key, or the total key. (# and/or * )
Jun 05, 2013 | Universal Office Adding Machine/Calculator...
My ac is not putting out much cold air if any at all. it is barely used and im trying to get it fixed. someone told me to use Freon, but i would like to know from a person who deals with this stuff.
I am not certain as to why it won't start it could be serval items You could try turning off and back on serval times as it could be a stuck contactor.or relay. as to adding freaon . no I don't think you need to add it .. the system is closed so unless it leaked out its in there for ever. hope this helps let me know
Jul 23, 2011 | Heating & Cooling
How difficult is it to repair a rear seal leak on a 98 durango
Go buy a can of Berryman's Chemtool B-12 (Auto Zone, Rieley's, WalMart, etc.). Have tools, oil, filter and drain pan on hand for oil change. Warm engine to operating temperature. SLOWLY add can of Berryman's to crankcase of running engine through long funnel. Adding too quickly will kill idling engine, so go slow. After adding, replace oil filler cap and allow to fast idle (2000 rpm or less) for 30 minutes. Turn off engine and drain oil immediately. remove dirty oil filter. Let drain for 30 minutes. Replace plug, spin on new filter, add oil (do not overfill); start with 4 qts. and start briefly and then turn off. let stand for 20 minutes and check with dipstick. Add slowly to bring oil up to full mark; NOT ABOVE. You have just repaired your leaking rear main seal. Berryman's softens and expands rubber seals, stopping 95% of leaks caused by dried out rubber seals. DO NOT use this on cars/trucks that use the old fashioned rope seals. Ask a parts man what kind of seal a 98 Durango has. It washes the wax off the rope and it will leak worse than before. Ray (garage owner)
Sep 20, 2010 | Dodge Durango Cars & Trucks
When printing PDF colour documents data is missing I understand that adding memory may solve this - is this an easy thing to do , and is there a maximum memory I can add
Adding memory won;t help you. You have to set the print preferences to include everything in the document. If you are getting blue blocks with no data in them, uncheck the "Print Highlighted areas".
As for memory, each computer is a little different. Tiger Direct dot com has a memory checker. It will tell you how much and what type memory your system uses.
Oct 02, 2009 | HP DesignJet 500ps InkJet Printer
Will not restart after adding clothes
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. Wait for 2 minutes before trying the door. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Apr 19, 2009 | Whirlpool GHW9300 Duet Washer
Adding airtime
how do I add minutes to a verizon prepaid phone
Jun 13, 2008 | Cell Phones
Adding a channel to TEAC television
Hi I had the same problem so I bought a cheap universal remote controller and tuned into this model.
Once it is done, press a number on the remote controller and you can start to tune manually.
I do not know about the solution for AV channel.
Feb 14, 2008 | Televison & Video
Trouble adding the phone number for New Contacts.
how to add new contact to address book???
Nov 10, 2007 | Nokia 1100
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
