Question about Magic Chef Microwave Ovens
Installing a Magic Chef MCO165UW. Before installing it the vent fan blow out the front not the back vent that will hook up to outside vent. Will it vent to the outside once installed?
  • Laura Krebsbach
    Laura Krebsbach May 03, 2017
    So, instead of completely taking the whole thing apart to change the direction of the motor I just turned the entire fan unit around to blow to the back. Worked great!
    Top Expert:
  • Magic Chef Master
  • 51,218 Answers
Not unless you change the motor direction rotation
Posted on May 03, 2017
Back panel of microwave gets hot while in use
would you not also get hot when in use . if you were heating food to be totally cooked .that is why they have a fan in them
Jun 19, 2016 | Magic Chef Microwave Ovens
WHERE IS THE FUSE LOCATED ON MY MAGIC CHEF MCO165UW MICROWAVE
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 02, 2015 | Magic Chef Microwave Ovens
Where is the fuse for a 1964 FORD Fairlane?
I did not know Magic Chef made the Ford Fairlane!! Please post on the automotive area. It has fuses under the dash and under the hood.
May 22, 2014 | Magic Chef 1.6 cu. ft. Over-the-Range...
Where is the fuse
where is the fuse for my heater as its not working on my renult modus
Jan 03, 2014 | Magic Chef 1.6 cu. ft. Over-the-Range...
Magic chef mco165uw has no power
I didn't know they had noise filters! :)
Then you have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Nov 28, 2013 | Magic Chef 1.6 cu. ft. Over-the-Range...
I have an magic chef mvp V microwave and have just put in new cabinets. Do i need to cut an air vent in my cabinets or does it vent through the front?
Consult your installation instructions for that information.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
We're happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
Jun 05, 2009 | Microwave Ovens
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jan 08, 2009 | Magic Chef CMV1000B Microwave Oven
I dont know how to hook the vent fan for outside on the Magic Chef CMV1000B?
Dec 05, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
96 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
