Question about Pool & Spa
Mr Holmes used a product on one of his shows. i would like to get info on the product but cant remember what it was called.
It was a rubber product that was poured around a swimming pool on top of the existing concrete which was two tones of tan.
  • 11 Answers
SOURCE: Swimming pool cleaning robot doesn't move
Sound like your filter is dirty. Try backwashing if you have a sand filter, or clean your cartridges if that's what you have. A dirty filter will reduce water flow, which in turn affects the Nav.
Posted on Jan 02, 2009
  • 3 Answers
SOURCE: water pouring into 98 passat help needed urgently please
The vw Passat are known for this problem, you will usually find a crack on the plastic panel at the bottom of the windscreen, or else this same panel is incorrectly fitted. In this case alot of rain will get in through the pollen filter and through the heater box and lodge in the front footwell.
Posted on Feb 15, 2009
pcHelperDesk
  • 9 Answers
SOURCE: KX-TG5632 fell into the swimming pool. Can it be fixed?
Try drying it out in your car for a few days then put it back on the charger.
Be sure to remove the battery first.
Your car will act like a low dry heat oven.
Posted on Jun 24, 2009
protek480
  • 1723 Answers
SOURCE: swimming pool light on a gfi breaker
It won't take much to trip the GFI. Have you tried to dry the fixture out completely? Use a blow dryer and remove any moisture. Also, remove the light and cap the wires and try it if you can, it might be the wire.
Posted on Jul 23, 2009
  • 246 Answers
SOURCE: swimming pool heater
Buy 2 get of 12 gage wire solid pele off one end 4 inches
Make a u that end
Open heater laid down
Clean the orificies where the gas come out all of them
Turn heater on now
If not fix then Fo it again
Posted on Dec 03, 2014
Holmes HABF20 floor/box fan: broke one of the plastic feet that steadies the fan on the floor. Super glue no help. Are there replacement pieces available?
If you can't find a replacement plastic foot. You should be able to find rubber feet at a local Radio Shack. Replace the plastic feet with rubber feet. It will do the same. You may be able to find self-adhesive feet.
Jul 15, 2011 | Holmes Products HABF-20 Floor / Box Fan
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
Hi i havent used my radiator for 2 years is it ok to use now in my 8 month olds bedroom? also bit of a smell coming from it cant remember if i had that before or not is this normal for these radiator?
I would think it would be fine in your childs bedroom. First i would give it a good cleaning, brush it off,vacumn of blow out with compressed air. Also I would use your heater for a day or two in open area such as living room before I would trust it. I would guess that the smell you are getting is dust and hair,lint etc. burning off. But of course we don't want to take chances with our children. My son and daughter in-law used a holmes unit in my grandsons bedroom for the last four years and have had no problems. Hope this helps. Thanks
Nov 16, 2010 | Holmes Products HOH2501 Oil Filled...
What does "prr" mean when displayed on the LED readout of the Mr. Steam control panel?
Hi my name is Mike I am with Mr. Steam Product Support. PRR is a code that shows up on our Steam Bath controls it was not used on our Sauna's. The PRR means there is a problem with the temp sensor on the control.please call me at 800-767-8326
Aug 20, 2010 | Mr Steam Mr. Steam Allegro Sauna Model...
The rubber valve on my HM1745 has dried out and cracked. Where can I buy a new one?
REPLACEMENT ACCESSORIES
To order the replacement accessories you can do any of the following:
• Visit your local retailer
• Go to www.holmesproducts.com
• Call Consumer Service at 1-800-546-5637
If you have any questions regarding your product or would like to learn more about other Holmes® products, please
contact our Consumer Service Department at 1-800-546-5637 or visit our website at www.holmesproducts.com
http://www.appliancefactoryparts.com/content/pdfs/109660-1.pdf
Mar 19, 2010 | Holmes Products Cool Mist HM1745...
Have been looking for just one of the tanks as the rubber stopper rotted away. Do you know where I could just buy one tank?
you check at local hardware stores. or if your in canada check with canadian tire. if nobody has it locally. you might have to call the manufacturer to order it directly from them.
Aug 17, 2009 | Holmes Products HM4600-U 11 Gallon...
I am looking for one of these to buy... anyone know where I can find one? Holmes Products Halls HLS5000-U
you can try local hardware stores like target, walmart, walgreens, ace hardware. places like that. if not you can always call holmes themselves to order through customer service.
Mar 23, 2009 | Holmes Products Halls HLS5000-U Humidifier
Holmes HM4600HD humidifier tank
Mine dried out too. I could not find where to get the rubber valve seal for the tanks. Holmes does not list the part and when I called the rep told me they didid not stock the part. I solved my problem by purchasing thin rubber washers from Lowe's. They are 3/16 X 1 1/4 X 1/16 thick. The 3/16 hole in the center "snaps" on over the end of the plastic plunger just like the original. I had to trim the outside diameter with scissors to about 1" or using the old ones as a guide. Cost me $0.67
Nov 09, 2008 | Holmes Products HM4600-U 11 Gallon...
Holmes bh3955 or holmes hh3690
figure out your square foot requirements - multiply 16 X 20 to get 320 sq ft. Find a heat formula to consider windows and doors and known insulation in the walls. this will give you BTu output required to raise the inside air from 68 degrees (norm) to 72 degrees.
Dec 06, 2007 | Holmes Products BH3955-U Bionaire Utility...
Pool & Spa Logo
24 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
