Computers & Internet Logo
M
Marilyn Weiss Posted on May 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Howdo I change the password on my Arris router?
Marvin
Level 3:
Top Expert:
  • Arris Master 85,242 Answers
  • Posted on May 02, 2017
Marvin
Arris Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058255
Points
266281
2answers
What is password for arris DG3270A ROUTER
The default user name is "admin". The default password is "password", in lower case letters
How do I change access password
http://arris.force.com/consumers/articles/General_FAQs/SBG6580-Admin-Login-Setup
2helpful
2answers
Where to find the password
http://arris.force.com/consumers/articles/General_FAQs/SBG6782-Admin-Login-Setup
if you have not changed the default password and user name !
it is listed on the web page on the above link
Go to wireless tab at top of screen and look up WPA Key or WEP key and make a note of what it is on 2.4 GHz frequencies as I think this will be dual band with 5 GHz as well but Ipad will run on 2.4 GHz only as it will be 802.11n as opposed to 802.11AC
Note if you changed the user name password or user name you will have to reset the router back to factory defaults but be aware everything defaults so ISP cable settings reset (would need ISP to tell you what they are and help set them back up)
(wireless settings change so you need ethernet cable directly into router to set up wireless)
Hopefully your still set up on the router on the default user name and password !
Howdo I change or block my modem password from ay oe else usig it
You'll need to go in the router's settings and change the Administrator password.
2helpful
I need the arris wtm652 software, I can't change my wirelless security configuration without it.
don't need, just go to http://192.168.2.1
and if you can't access with the default password (think is admin :)
press the reset button of the cable modem just for router only, in case you have also telephony integrated.
go again to the address above and configure your password and router to whatever you like
hope this helps!!!
2helpful
Ok this is my problem i have a time warner arris tm602 modem i want to set up the wireless connection to my xbox 360 i need the wep key for this i want to know the default gateaway and/or the default...
The default username and password for most routers I have seen is admin and admin provided you have not changed it. All are lowercase letters.Also I suggest you use the WPA or WPA2+ encryption if its available. The WEP is easy to crack wirelessly and I had a gala time cracking my neighbor's router in less than 3 hours!
How to secure my d-link wireless adapter with my Arris 550a modem
To make your wireless router secure you need to use your browser and type in the router's IP configuration address.
Then you need to change the default Admin password,
change SSID and turn off SSID broadcast,
setup the encryption (use WAP or WAP2 if your wireless card supports WAP) if not use WEP 128 bit encryption
and for added protection use MAC address filtering.
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
