Question about Cell Phones
What is the proper period to charge phone with the charger ?
    Top Expert:
  • Cell Phones Master
  • 79,123 Answers
You charge it for at least 8 hours when the phone is first used and then charge it until the battery indicates 100% charge.
Posted on May 02, 2017
Tablet doesn't turn on, it shows a battery with an triangle and this symbol!
When you have the charger plugged into the tablet and wall outlet does the triangle change to a lighting bolt if it doesn't change try a different changer either the charger or charging port or charging cable might be bad
Dec 31, 2014 | Tablets & eReaders
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jun 18, 2014 | Samsung Galaxy S 4G Cell Phone
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
Samsung sgh z230 charging problem .. plsese help brother
Hi,having charging problem with your phone,you might not be too sure where the problem is really from, you will need to look out in two directions.
!.The charger your using,
! The charging port of the phone.
The charger might not be working properly and will not allow you to charge your phone properly.
You can use another charger to test if it will charge properly.
Also when you check the charger and it's working, You might need to replace the charging port area.
The charging port is the port that you insert you charger into the cell phone.
When you check those two out,am sure you will find a solution.
Take care.
May 25, 2011 | Samsung SGH-Z230 Cellular Phone
The battery drains far too quickly on my Samsung G600 (have tried new batteries but same problem). Any idea what is causing the power drain?
In many instances, some phones run a lot of applications in the background unfortunately, in most cases of a fast battery drain, it is due to high screen brightness or a long screen time-out. Try turning down your screen brightness to a lower setting (one which you can still see without straining) and check to see how long your screen turns off. Some phones default to 30 secs or 1 minute. Use a lower setting if possible.
Also, cell phone batteries are lithium batteries. At first use and then on a periodic basis, try draining the battery until the phone will no longer turn on and only then plug your charger in. If you plug the charger in before it is dead the battery will not be used to its fullest capacity. Hope this helps!
Feb 28, 2011 | Samsung SGH-G600 Cellular Phone
My phone wont charge i always have to put it in a different position too get it too charge wats wrong with it?
Hi, there are two things you will need to test for ,
The charger and the charging port.
The charger of the phone might not be contacting properly causes it to fail or loose contact, that might be the reason it needs to be position properly before it charges.
You can use another charger to see how firm it will on another phone, so that you can be able to know if you will need to replace the charger with another one.
The charger port is where you plug in the charger to the phone for the phone to be able to charge.
Sometimes if the charging port is weak,itmight not be able to hold the charger properly,it will be failing contact.
Also you can use another charger to test with your phone and see how firm it holds on the phone and if it will charge the phone without failing.
I guess when you test for the charger and the charging port, problem will be solved.
Feel free to pass your comment.
Thanks for using fixya....
Jan 11, 2011 | Sanyo Cell Phones
The radio is not charging has new battery
Check your battery contacts on/in the radio, battery and charger. Clean with a pencil eraser if needed. If your charger will accommodate the battery alone, try charging the battery outside the radio. Does the charger's light (if any) come on and stay on when the battery/radio is attached? If so, your charger is working properly. If the light (if any) on the charger is flashing you may have a shorted or bad battery. Check your user guide to the radio/charger for more information. Finally, periodically a battery has too low of an initial factory charger to start charging on the charge immediately. Try placing the battery on the charger for 3 complete charge cycles, and see if it will then charge. If the battery is new, you might want to contact the vendor for a replacement.
Aug 22, 2009 | Yaesu Radio Communications
Phone's not getting charged. Gets overheated
U see the phone getting heated is a serious problm..Check if the battery is rightly plugged in..
On my part I wud recommnd to pay a visit to yr service centre as soon as possibl.. Yr phone battery cud easily b replacd if its in d warrnty period..
Apr 13, 2009 | Cell Phones
BATTERY CHARGER RADIO SHACK DELUXE 10 CELL
I would go to Radio Shack and have them explain the proper charging procedure as well as inquire about the red and green lights as not all chargers go green when fully charged-Normally red indicates a charging action and if a charger has no fully charged light, then a required charge time period is noted in the instructions. Batteries can be ruined by over charging!
Jan 03, 2008 | Energizer Rechargable Battery with Charger
GE 6.0 Dual Cordless Phones
No, the battery packs can not be ruined by leaving them in the charger. It is wise to keep both handsets charged up all the time. It won't hurt to leave them off the charger for extended periods..even several days. Of course, the amount of power left in any battery depends on at least two things: the amount of time since the last charge (yes, they do lose power just sitting) and the amount of use since the last charge. In this case, we are dealing with nickle metal hydride batteries and they do not develop a memory like nickle cadmium batteries do. Charge 'em up and just place them back there periodically or always. Not to worry.
Dec 29, 2007 | GE 28112EE2 Cordless Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
