Question about John Deere Garden
What causes a Brigg's & Stratton motor 31P677-0132-B1 - Briggs & Stratton Engine to flood out?
I have a John Deere La 105 riding mower 31P677-0132-B1 - Briggs & Stratton Engine that is flooding out. I has an electrical connector that goes on the bottom of the fuel bowl & I'm not sure what that wire does for this motor. Does anyone know what the problem is? This mower only has little over 60 hrs..
    Top Expert:
  • John Deere Master
  • 77,169 Answers
Most common reason is a sticking float or fuel inlet valve.
Posted on May 02, 2017
  • 3 more comments
  • sherman north May 02, 2017
    How do i fix this, it has an electrical connector on the bottom of fuel bowl.
  • yadayada
    yadayada May 02, 2017
    rebuild the carburetor, what did you think?
  • sherman north May 03, 2017
    Might be able to clean it. Thank you
  • yadayada
    yadayada May 03, 2017
    Clean it but use compressed air to clear the passages and jets.
  • sherman north May 25, 2017
    Thanks
I need a color coded wiring diagram for a john deere La130 automatic riding mower w/ 18 hp Briggs and Stratton motor
A wiring diagram is something you would have to request directly from John Deere.
Aug 13, 2016 | John Deere Garden
Where can i find a John Deere la115 wiring harness diagram?
The John Deere site has the wiring harness diagram on the LA115 parts diagram in the Electrical section (section 40, page 19). Start here: https://www.deere.com/en_US/parts/parts.page and select the Parts Catalog. http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt is where I ended up. The carburetor is in section 30 (Fuel and Air), page 10.
I hope this helps.
Aug 03, 2015 | John Deere Garden
John deere d105 auto
It floats?? but the carburetor still leaks fuel ????
Fuel is HIGHLY COMBUSTIBLE! Please read the safety notes in your owners manual before attemting this repair. Lawn Mower Carburetor Repair Small Engine Maintenance Briggs Stratton
Apr 12, 2014 | John Deere 420,1020,2010,2020,2510,2520...
14.5 horse I/C ohv with oil
sounds like the needle valve and seat in the carb is bad
Jun 02, 2012 | John Deere Garden
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
I have a John Deere LA140 Automatic riding lawn mower. I need the diagram to know how to put on the new belt. Belt path?
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
That should help. It's on the John Deere website.
Nov 15, 2009 | Briggs & Stratton Garden
2001 john deere saber briggs moter smell gas in oil
If you're using ethanol-blended fuel, the ethanol will eat away at the neoprene parts inside the Briggs carb.Going to need a carb rebuild.
Don't run your engine until it's fixed or you could damage it as gas will pour into the crankcase, causing the oil to thin and lose its lubricating ability.
Sep 09, 2009 | Briggs & Stratton Garden
Garden Logo
57 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
