Question about Lands Phones
What is a "Soft Key"? - Lands Phones
    Top Expert:
  • Lands Phones Master
  • 77,202 Answers
It refers to the input method.
Posted on May 02, 2017
Where is the select button on the handset of DECT 4086
The Select key will be one of the soft keys below the handset's display. I believe it's the middle soft key when in a sub-menu. The display will have the labels for the soft keys above each key. The soft key labels change depending on what you do with the handset. Thus read the display to confirm which soft key should be pressed during an operation.
At least when you navigate the Phone book from the handset, Select is the middle soft key. This is shown clearly in the manual on page 27. You can see this manual here: http://www.payphone.com/shop/instructions/DECT4086.pdf .
I hope this helps.
Sep 28, 2016 | Uniden 40862 DECT Cordless Phone
We bought KX-TG4024 cordless telephones. Can the ring tone be changed?
I have a similar model and the ring tone can be changed.
To change on the Handset
1, Press Menu
2, Scroll using arrow up/down key- go to "Ringer setting" then press soft key Select.
3, Scroll to "Incoming call" then press soft key Select
4, You can scroll to "ON/OFF or 2".. Maybe your phone has more choices. Number 2 will be a different ring tone.
5, Press soft key "Save" then press OFF key.
The Base Unit
1, Press Menu
2, Scroll using up/down arrow keys to "Initial setting" press soft key Select
3, Srcoll to "Set base unit" press soft key Select
4, Scroll to "Incoming call" press soft key Select
5, select ON/OFF or 2 with arrow keys
6, Press soft key "Save" then press OFF key.
I hope this has been helpful..
Aug 29, 2011 | Panasonic Cell Phones
I want to make my phone touch tone
I presume you want to use tone dialling..If that is the case the solution should be same as my phone.. Press Menu then scroll using up/down arrow key to "Initial setting" and press(soft key) Select, then scroll to "set tel line" press(soft key) select, then scroll to "Set Dial mode" press(soft key) Select, then scroll to "Tone" , then press(soft key) Save then press Off button.**This is done via handset**Soft keys are the ones under screen*** I hope this has been helpful.
Aug 25, 2011 | Panasonic KX-TG2313 Cordless Phone
I CANT DELETE CONTACTS lg gs290
From the main menu screen, press Contacts [Right Soft key].
Press Options [Right Soft key].
Select a contact from the contacts list.
Press the Right Soft key for options.
Scroll to Manage Contacts, press OK
Select Erase, press OK.
Press Right Soft key to select all or select desired contacts to erase by pressing OK to mark each contact.
Press Left Soft Key for Done.
Display shows Erase Contacts?
Select Yes, press OK.
If this does not work, "Power the phone off for 30 minutes and then power it back on and try it again."
Regards
Jul 18, 2011 | Cell Phones
How to check wap profile in my s3500 mobile?
1. Press 'Menu' (Navi key).
2. Highlight the 'Settings' and 'Select' (left soft key).
3. Highlight 'Application settings' and 'Select' (left soft key).
4. Highlight 'Browser' and 'Select' (left soft key).
5. Highlight 'Browser profiles' and 'Select' (left soft key).
6. press 'Options' (left soft key).
7. Highlight 'Add new connection' and 'Select' (left soft key).
Nov 11, 2010 | Samsung S3500 Cell Phone
It wants pin code and puk
To change the PIN number on the phone,
  1. Press Menu (left soft key)
  2. Highlight Settings and press OK (left soft key)
  3. Highlight Security and press OK (left soft key)
  4. Highlight Change codes and press OK (left soft key)
  5. Highlight PIN code and press OK (left soft key)
  6. Enter your old PIN code then press OK (left soft key)
  7. Enter your new PIN code then press OK (left soft key)
  8. Repeat your new PIN code then press OK (left soft key).
Aug 07, 2010 | LG GB102 TMOBILE PAY AS YOU GO MOBILE...
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
Gives wrong time and day
This is from the Manual. If you want the whole manual, at the end of the instructions, there ia a link to the manual.
Setting Day and Time
Day & Time sets the day and time of your display.
1) Enter the Global Setup menu, and then the Day & Time
submenu option (see "Entering the Menu" on
page 17). Image is for the base.(Here is how)
Entering the Menu
1) In standby mode, press the MENU soft key.
2) Use volume up/down to move the pointer to a desired
main menu (DirectLink Mode, Room Monitor, Handset
Setup, Base Setup, Answ. Setup, Global Setup, and
Deregister HS).
3) Press the OK soft key to select the desired main menu.
To return to the previous screen, press the BACK soft
key.
4) Use volume up/down to select a desired submenu and
then press the OK soft key to enter.
5) In the submenu option, use volume up/down to select
an item. Press the OK soft key to confirm your
selection. For detailed instructions, see the following
sections for the desired submenu option. To return to
the previous screen, press the BACK soft key.
6) To exit the menu, press end on the handset or cid/exit on the base.
2) Press volume up/down to select the day of the week,
and then the → soft key.
3) Press volume up/down to set hour, and then press the → soft key.
4) Press volume up/down to set minute, and then press the → soft key.
5) Press volume up/down to choose A M or P M, and then press the SAVE soft key. You
will hear a confirmation tone.
http://www.uniden.com/pdf/TRU8885-2om.pdf
Jan 08, 2009 | Uniden TRU8885-2 Cordless Phone
Uniden 5.8 powermax
From the base unit, press the "Menu" soft key.
Press volume up/down button to highlight "Global Setup" and press "Ok" soft key to select it.
Press volume up/down button to highlight "Day and Time" and press "Ok" soft key to select it.
Press volume up/down button to select the day of the week and then press the right arrow soft key.
Press volume up/down button to set hour and then press the right arrow soft key.
Press volume up/down button to set minute and then press the right arrow soft key.
Press volume up/down button to choose AM or PM and then press the SAVE soft key.
You will heart a confirmation tone.
Hope that helps,
Ken
Mar 17, 2008 | Uniden TRU8885-2 Cordless Phone
No instruction manuel
Hope that helps,
Ken
Jan 19, 2008 | Uniden TRU8885-2 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
