Question about Cameras
My yoga3 when unlocked goes to camera and when I clear then camera it returns to locked. When unlocked it does it again. Help please!
2 Suggested Answers
  • 180 Answers
SOURCE: control lock problem
try to check 78L05 - 5 volts to eeprom.
Posted on Apr 19, 2008
2006 KIA.DOOR LOCKS; When you unlock the doors with remote, the doors immediately lock again. With the key, door unlocks and stays unlocked. however, the feature when you turn key to the right two times...
intermittant is spelled intermittent. .... Ah, locking system. ... You will find a broken wire in one of the doors that are used to set the door lock.
Probably the drivers door return wire.
Oct 26, 2013 | 1998 Honda Civic
How to unlock a trio stealth pro 4.0 0S if forgot pattern lock
i got a trio stealth about a year ago but now my son lock it and cant find a way to unlock it pattern please any one help me with this thank you so much
Dec 26, 2012 | Mach Speed Trio 4GB 7" Trio Stealth Pro
How could i unlock the simcard for my canon G10 powershot camera... please help!
It's not a SIM card, they only go in mobile phones.
You must mean the memory card. The G10 takes up to a maximum 8GB SDHC card, and like all SD and SDHC cards it has a locking switch which can accidentally be activated.
Look at the top of the card (i.e. label side up, clipped corner to the top right). Quarter of the way down on the left edge of the card is a tiny switch, fully forward (towards the electrical contact end of the card is unlocked, anything else can be locked.
If the switch is clearly in the locked position then slide it firmly until it clicks into the unlocked position. if it's already unlocked, slide the switch fully to locked and then fully back to unlocked until it clicks.
If that fails then try another unlocked card to see whether the fault is with the card or the camera.
Feb 26, 2011 | Cameras
Hi I cannot clear the pictures off my camera - camera says protected card? I need to clear my camera off all photo's - so what do I do please. Regards Debs
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 18, 2011 | Cameras
Get the error The Card is locked when I switch on
lock and unlock option is on the card,select unlock option,then try.
Mar 09, 2010 | Casio Exilim EX-S880 Digital Camera
Digital camera says sim card locked
Remove the SD memory card and you see there is a small locking switch on the card which is used to protect your data. Slide the switch away from the locked position. If already unlocked then slide it fully to locked and then firmly back again.
If this does not work then you must try another SD card (2GB maximum on your camera).
I hope that this solves your problem, please return the favour by rating my answer.
Oct 17, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
My vivitar camera when openned staes card locked how do i clear this
on the left side of the memory card there is a lock switch. if the switch is up, its not locked. if the switch is down, its locked. theres also another type of sd card when theres a tiney memory card that goes in the bigger one. take the tiny card out and its locked. put it in and its unlocked. did i help?
Oct 09, 2009 | Cameras
How do I unlock memory card on my canon powershot sd450?
Remove the SD card from your camera and look at it closely. You'll see a small switch which is used to lock the card to protect your data. You will most likely find that the switch is set to the locked position. If it isn't, slide the switch fully to the locked position and then fully back again before trying the card again in your camera.
If this fix has helped then please return the favour by rating my answer. If you still have a problem then please add a comment and I'll come back with further suggestions.
Oct 08, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Control lock problem
Apr 02, 2008 | Computers & Internet
Need help quick
I had the same problem just this morning...but I fixed it!
If you have manipulated any of the files on your opening them on your computer and modifying them...then the camera won't decode them. This is because the dimensions change and exceed the dimensions of the camera. Try returning your pictures in your camera file to their original state and saving it to the camera. Don't forget to delete the ones that don't work. This should work.
Nov 25, 2007 | Sanyo DSC-SX500 / VPC-SX500 Digital Camera
Cameras Logo
26 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
