Question about Acer Computers & Internet
How do I adjust touch screen sensitivity on Acer one 10?
    Top Expert:
  • Acer Master
  • 80,637 Answers
I know of no adjustment that can be made it is a fixed value.
Posted on May 02, 2017
Testimonial: "Thanks it's a lil' surprising there's no adjustment I guess I'll have to just get used to what feels like pounding on screen.."
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Acer X163w monitor auto adjust keeps popping up
Check to see if you have any dust, or grim by the buttons. I cant recall if this monitor's buttons are touch sensitive or not, but a good cleaning to make sure they are not stuck should clear the issue right up for you!
Aug 31, 2012 | Acer X163w Computer Monitors
My acer aspire 5742Z touchpad is too sensitive or I don't really know how to use it. Every time I touch it something stupid happens on screen. Now it has turned my screen dispay side on and I have to use...
Definitely your touchpad is TOO SENSITIVE!
To modify the sensitivity just go
START > CONTROL PANEL > MOUSE/TOUCHPAD and adjust there the sensitivity by dragging the cursor to the LEFT until it reaches the middle.
In PROPERTIES just re-invert the functions of your touchpad to get rid of the mixed axes.
Mar 03, 2011 | Acer Aspire 5742Z-4200 Notebook
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
Pointer jumps around on screen when touching touch pad
hello, have you tryed adjusting the sensitivity of the touch pad to a less sensitive touch ?
Mar 31, 2009 | Acer Aspire 5610 Notebook
Instinct M800
Touch Sensitivity
1. Press Home > and touch Main > Settings > General > Touch Sensitivity.
2. Touch and drag the slider left or right to adjust the sensitivity level.
_ Touch the onscreen Touch Here button to gauge the response of the new sensitivity level.
3. Once you are done, touch Done.
Jan 17, 2009 | Samsung Instinct Cell Phone
Acer aspire touchpad over sensitive
Your laptop should have software pre-installed for your touchpad. This should probably be in the Control Panel. Once you find the software there should be options to change the sensitivity. Hope I helped.
iSpearz.
Jan 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
How to adjust sensitivity on ELO Touch Screen monitors
you probably have a capacitive screen, it only responds to finger press. You need a resistive screen to be able to respond to finger, nail, or pen press.
Aug 28, 2007 | Elo 15" Touch Monitor
Computers & Internet Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
