Question about Singer Sewing Machines
What is the hold position on the singer memo Matie 700.
How to replace bobbin case in Singer 771
The link below answers all questions for the 700 series machines. Singer 700 Series Touch Sews
Feb 09, 2017 | Singer Sewing Machines
Model 700. Where can I get a repair manual?
SINGER 700 MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > SINGER Manuals > Other > 700 View and Download SINGER 700 manual online. 700 pdf manual download.
Nov 03, 2015 | Singer Sewing Machines
I have singer memo matic 360/260. I want to know how to use punch card
They are available for free here: http://knittsings.com/knitting-machine-manuals/
Oct 06, 2013 | Singer 132QRFB Mechanical Sewing Machine
Im trying to fnd a manual for 321 singer memo-matic machine
The manual is available for sale (electronic copy $5) here: http://www.theknittingcloset.com/pd-knitting-machine-manuals---e-transfer-downloads.cfm . Select the 321 model in the Studio/Singer/Silver Reed/White drop box and then click Add to Shopping Cart.
The basic directions for Singer Knitting Machines are here http://www.ehow.com/how_5675461_work-singer-knitting-machine.html .
I hope this helps.
Jun 17, 2011 | Singer Sewing Machines
Need spare part for SINGER 700 (DOMESTIC SEWING MACHINE) Its hook that fitws under the bobbin case
You can try www.sewingpartsonline.com and they may have the part you are looking for. If not, call Singer at 1-800-4singer Good luck
Feb 08, 2011 | Singer 3270 Mechanical Sewing Machine
Can't get the bobbin case back in on my singer hd 110. It came out on it's own. The manual is not very helpful.
If this is a vertical/metal bobbin case; raise the needle to it's highest position. This will position the shuttle to accept the bobbin case.
If the bobbin case has a lever on the back, lift it and hold it open as you place the bobbin case back into the shuttle. It should click into place.
Mar 14, 2010 | Singer HD-110 Mechanical Sewing Machine
I have an old Singer Memo-Matic 360/260 KNITTING MACHINE. I pulled the machine apart to repair a small dent and put it back together again. The carriage works only in one direction. Can you help me?...
yes a sping must have come off tip it upside down and move the tuck slip etc lever and see that they move, you will see the course that the needles should take, take a close look and see which part of the cams move underneathe try both sides and you will find that one wont match up maybe a pring has popped off or broke good luck. oh also check the side guiders that feed the needles into the carriage, maybe one has been knocked or dented..
May 15, 2009 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
22 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
