Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
Device cannot work
My 160 gb simple drive wont work. when i plug the usb port in, yhe found new hardware icon pops the immeadetly after i get a pop sayingcannot connect to device. ive used it many times but never had this problem. ive unplugged it may times without going to the safley remove hardware icon, now the comp. dosent reckognize it anymore
  • 5 Answers
Try cleaning your computer for spyware and viruses. Also try cleaning your registry out using a utility. Do your USB ports on the computer work with any other devices? Try using different USB ports and make sure theres no faults in you device list with the USB drivers. Let me know more info. What OS are you using. By unplugging it without safely removing is most dangerous to Flash memory but it's definitely possible to damage a hard drive by doing so. You might have corrupted your drive. Hope this helps.
Posted on Jul 25, 2009
Is my simple tech 60GB compatable with windows 7 the disk said for windows 2000 and xp
Most portable hard drives work with any operating system
Plug and Play is a simple Windows controller that enables your Windows computer to recognize and adjust to hardware changes and devices plugged on your computer such as hard drives, memory cards and USB and Firewire-powered devices with little or no input from a user. If your system is not recognizing plugged-in hardware, the plug-and-play device may be disabled and may cause instability on your system. Enabling this feature is simple.
Click "Start" on your computer screen and then click "Run." Type in services.msc on the run window and hit "Enter." Scroll down the services window and right-click "Plug and Play." Click "Properties" on the pop-up menu. Select "Automatic" under start-up type if it is disabled. Click "OK" to save the changes. Click "Start" on your screen and click "Control Panel." Double-click "System" and click the "Hardware" tab. Click the "Device Manager" button and then right-click the plug-and-play device you want to enable, then click "Enable." Close the device manager. Hope this helps.
Dec 23, 2012 | SimpleTech SP-U25/60S 60 GB USB 2.0 Hard...
Usb ports not recognizing pen drive, external drive, ipods or iphones but 2 out of 3 usb ports will charge the ipod and iphone. please help!! I've tried unplugging, removing battery, device manager says...
Generally USB ports are part of the motherboard so you will not be able to replace just the USB ports. you can try to uninstall the USB controllers in device manager then reboot your computer. they should automatically get reinstalled. also try booting to safemode and check if it will recognize your USB devices.
*if you get a pop up for found new hardware when you plug in any of your USB devices then it would usually indicate that the hardware is working fine and the problem is with your OS
Mar 31, 2011 | Sony VAIO VGN-FW285J/H Laptop
My laptop is unable to detect and install the driver
Hi
1 Restart your laptop ansd connect the drive again.
2 if that too fails. then follow that
Go to the My computer icon. right click on it. Select manage. one window will pop up select device manger and the in the right side a window will come . select the option of USB. The port with which ur hardware is connected will show with yellow error mesage. slect that port and unistall the driver and select the main menu of the USB and select the option scan for the hardware changes
Regards
Vipin
Jan 26, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Could not open the flash drive. i think the drivers is not loading
when you plug the usb dose the computer recognize it and gives you a pop up new device found.
if yes then right click on the my computer icon go to manage and go to diskmanagement and see the drive and its there but dosent have a drive letter on it just right click and say change or add drive letter and it will apear on the my computer .
if it dosent recognze it when you connect theneither your usb port is disabled or the flash drive have an issu
to be sure try to plug this device in other computer if it works over there then its your usb port blocked by anti virus you are using .
or the port is not working properly.
thanks
Dec 13, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I plug in my external hard drive into my usb port but i go into my computer and i cannot find the hard drive my computer makes a noise when i plug it in but no pop up or change in my computer
U open your my computer window. Any blank place click right button, properties, hardware, device manager, total hardware configuration. Just select any one option & u click the box of title bar (Scan for hardware changes). U try reconnect & connect the device.
Jul 07, 2010 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
My Book 500 GB does not work with Vista
For that you have to uninstall all usb drivers from computer then it automatic installed.
Right click on my computer icon then click on property then click on hardware then device manager.
In device manager you can see all driver list.Go to usb controllers then uninstall all usb driver 1 by 1 when you right click on usb driver click on uninstall.
Then restart computer then check.
If still face same issue then right click on my computer icon then click on manage then go to disk management
Then removable storage check you find there your drive if you find then explorer it.
Also check in bios that USB Legacy 2.0 is enabled.
Let me know if you need more assistance.
Thanks.
Oct 01, 2009 | Computers & Internet
Need help with western digital wd3200me passport
if it came with a driver disk or an install disk then try running that before hooking up your harddrive
Jun 01, 2009 | Western Digital Elements powered by WD 320...
External USB Disk is installed but not visible under Mu Computer
Go to manage, refresh, and then asign a letter to it.
--- tuljo
Feb 23, 2009 | Western Digital External USB 2.0 80 GB...
I bought the same product, I noticed that connecting the device to the USB ports at the back of the PC body and using shorter cable solved the problem, try each of the ports at the back of the PC.
Jan 10, 2009 | Computers & Internet
PC Does not recognize HDD
there is a complict device driver in the device manager. .. configure device manager and remove an auknown device driver especially the usb device and restart the computer
Mar 08, 2008 | Beyond Micro Mobile 80 GB USB 2.0 Hard...
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
357 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
