Question about Troy Garden
Troy bilt riding mower, model 13cx79kt011. I removed the deck. tried to remount it, the deck lifting arms bring the deck mounting brackets so high the brackets hit the frame. how attach lifting lever?
Deck lifting arms attached to deck lifting brackets bring the brackets so high they hit the frame. I had removed the deck, when I try to remount it the height of the brackets hit the frame and I can't get the deck above the third slot for the lifting lever. The attachment adjusting levers I have reattached to the inside surface of the brackets in the correct hole but somehow there's a misalignment and I can't see it.
4 Suggested Answers
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
  • 843 Answers
SOURCE: I have model 12A-569Q755 serial
Here's an exploded view.
Good luck
Posted on Aug 19, 2010
  • 10319 Answers
SOURCE: I just installed a 48"
study the photo in the webpage link as given below for towards the rear of the cutting deck you will see a left and right side support for the swing arms on the handle that slides into the eyelets of these 2 supports. the frong has two bars, left and right that attach to the front from the front axle area. locking pins hold these rods in place shape like a hair pin
Posted on Apr 23, 2011
How to reinsta l idler pulley arm
Commercial Mower Maintenance-Replacing Idler Pulley ...
? 3:44
Sep 30, 2011 - Uploaded by askanthonynow
After new bearings were placed into an idler pulley, it is being installed on the deck of the mower. This is the .
How to Replace the Deck Idler Pulley on a Troy-Bilt Pony ...? 13, 2013 - Uploaded by eReplacementParts.comThis tutorial will show you how to remove and install the idler(4.25") pulley on a Troy-Bilt Pony lawn tractor/riding mower. Helpful items include ...How to Fix the Idler Spring on a Zero-Turn Mower ' Home ...
Nov 01, 2015 | Yard Machines Garden
Mower belt diagram
Try Goggle it. belt diagram troy -----
Aug 03, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Belt diagram
One end hooks to the idler pulley arm, the other hooks in a slot in the deck.
Jul 20, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
I need a detailed diagram for replacing the mower deck on my Troy bilt 42" Pon y tractor.
It is the reverse order of cutting deck removal on page 22 of the manual below.
If the manual is incorrect go to this site:
Enter your model AND serial number and then download the manual. Look for deck removal procedures and then install it in reverse order of removal.
Thanks for choosing FixYa,
Aug 25, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I recently purchased a Troy Bilt Bronco riding mower from a local Lowe's Store. It was delivered by a flat bed truck. The mower was removed by placing the forks of a fork truck under the mower deck and...
I never heard this problem before.
It would seem to me that if you were to lift a mower with forks, they should NOT be under the deck.
I have a Craftsman and I think my deck is bent, I can't align it in all the directions the way I should be able, maybe they did that to mine.
I would call Troy Bilt; it's important enough.
May 31, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
Aug 13, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
Garden Logo
42 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
