Question about Garden
How do i takes blades off white lt 12 - Garden
Oil amounthow much oil does a white lt 12 use
as much oil as it takes you get to the full mark on the dipstick.
Aug 29, 2016 | Garden
Snow blower will not throw snow far
I take it that you have a 2-stage snow blower, that is is has the auger blades and then the 2-stage impeller. The impeller blade is damaged <<OR>> the motor is to small to through the snow far. If you have a 5-horse engine and throwing heavy snow, the snow may not go as far as the light fluffy stuff.
A single stage snow thrower is not designed to throw snow far, just move it over a bit.
Oct 10, 2014 | Garden
I have table saw (r4510)it has a spliter mounted on the side next to the saw blade hold question how do I get the spliter out of the holed out?
I assume you are talking about the riving knife behind the blade.
when you take the hole cover off the saw table, you'll see a lever down on the side of the riving knife that can be either straight up or you can pivot it down toward the blade. When its up, its for through cuts, the riving knife sticks up higher than the blade. <b>When you turn the lever down toward the blade, the riving knife drops down a bit so you can make kerfs that don't go all the way through the wood.</b>
When you take the blade out, you can also take the riving knife out if you are going to put a dado cutter in, but <b>don't remove the riving knife</b> otherwise.
Wood has all kinds of internal stresses that are relieved when you cut the wood. Often the slot the blade cuts results in the two sides of the wood curving together and pinching the blade. This if very dangerous because the back of the blade can get pinched and through your wood at you faster than a major league pitcher can throw a fast ball. I still have a bruise on my chest from this happening to me before thanksgiving. Good thing it was the whole end of a 2x4 and the wood didn't split into a sharp spear as the blade grabbed it. Don't take out the riving knife unless you are using a dado blade and then put it back in right afterwards.
If you don't have one, here's the manual for your saw:
http://tinyurl.com/npkv29o
Oct 06, 2014 | Saws
Light switch wiring
Yes.
The code is maximum 12 boxes per circuit breaker.
You can connect a 12-2 NM W/G cable to one of the outlets. Black-to-black and white-to-white and ground-to-ground. Black is hot, white is neutral, and ground is ground. And bring that cable into a hollow-wall box you install 50" high on the wall. Then run the 12-2 cable up to your light fixture.
http://waterheatertimer.org/images/GE-15312-single-a-300.jpg
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/OWB1.html
You can also replace one of the outlets with a combo switch-outlet. The run singe 12-2 cable up to light.
This wiring diagram shows half way down how-to-wire-switches page.
Outlets have wide blade on neutral side, and narrow blade on hot side.
The black hot wires from old outlet connect to side of combo device with narrow blade.
The white neutrals from old outlet, and new wire going to switch, all connect to silver screw on wide-blade side of new combo device.
The black wire going to new light connects to screw next to switch located on wide-blade side of device.
Aug 28, 2012 | Electrical Supplies
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
Dec 16, 2010 | 1996 Jeep Grand Cherokee
Craftsman lt 2000, blade not staying in place
i would need a complete sears model number to look this up for you, however, you will need to remove the intire blade spindle housing, then you can remove just the shaft from the housing. and just replace the shaft. Will save a lt of money.
if you can find the complete model number you can go on the internet to
mtd.com/parts or to ayp.com/parts
and you can pull up a parts diagram and find the exact part number and order it online, or take model number to sears and they will either have it in stock or can order it for you. Sears will however cost you a fair amount more then ordering online. I hope this helps you
May 28, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
White LT-12 lawn tractor 139-656-190 Mower deck on right side is out of alinement. Rear tire rubs on deck when lowerd. How do I ajust the deck?
I have exact same problem with my 1989 built LT-12 White tractor ! I Discovered that the Right side connecting Link #14802A,that connects the lift handle shaft #17154A with the Stabalizer bar #16465A, was broken where it connects with the Deck Lift handle shaft.
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
Pull on/off switch
Put one wire from switch to black wiring coming in and the other to the black going to the ballast.
If you do not understand please post back
Dec 01, 2008 | Electric Door Light Switch
Attic roof vent fan- brand unknown. need motor and blade
Any Blade will be ok if it will fit shaft and they all should be cosistant and of course the higher the amp the better quality.I like the Pro 3 model at Home depot but I believe the Pro 1 gable is the 12 inch blade,pro 3 is 17 inch houseing and maybe 12 inch also.
Please rate jj505 Guru
Jul 11, 2008 | Kitchen Ranges
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
