Question about Dell Computers & Internet
Computer will not boot, instead get unmountable boot volume and unsuccessful self fix by computer. How do I best salvage files and programs on hard drive I will be replacing?
Dell Insperon 15 3000 series
    Top Expert:
  • Dell Master
  • 78,257 Answers
You can send the hard drive in and have the files extracted from the drive disc(s) but it is very expensive. Many website offer the recovery service for failed drives.
Posted on May 02, 2017
SOURCE: Crash and Burn dell inspiron 8600 Help
my computer when start I saw the logo of windows, but faster the screen its turned black and dont nothing. I reboot all componet and give me a msg fan are RMP=0, and the hard disk do nothing too.
Posted on Jun 22, 2008
  • 148 Answers
SOURCE: computer won't boot into windows
The event of you inserting a DVD is unlikely to have anything to do with this problem. Probably just a coincidence that it happened after you did so. Hard drives die eventually and more frequently so in laptops.  I'm afraid you will have to bite the bullet and replace the hard drive.
Posted on Dec 11, 2008
antiochpc
  • 1314 Answers
SOURCE: blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Posted on Jan 18, 2009
shakeelm
  • 224 Answers
SOURCE: HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Posted on Mar 07, 2009
SOURCE: Removal of boot.com virus from external hard drive and USB Stick
Silakan baca di >sini<
Desi Vibes
"boot.com" is a virus which attacks the hard drives & the hard drives could not be opened by double clicking. In hard drives after enabling viewing hidden file u can see some "autorun" file & a file named "boot.com" which cannot be removed just by deleting.
Here’s the REAL way to clean this off your system. You should do these steps after a fresh reboot in safe mode.
1) Navigate to the problem drive(s) via the Explore option.
2) Click on TOOLS -> FOLDER OPTIONS
3) Click the button which says ‘Show hidden files and folders.
4) UNCHECK the following boxes:
Hide extensions for known file types
Hide protected operrating system files
5) Find and delete the autorun.ini file and the resycled folder on the root directory of all affected drives.
6) Check “c:\windows\system32\dllcache” for boot.com file and delete it if present.
7) Check “c:\windows\prefetch” for boot.com file and delete if present.
8) Delete all files from c:\windows\temp
(Some files may not delete, that’s ok, they’re in use by the system and not virus files.)
9) Delete all files from c:\Documents and Settings\[USER PROFILE]\Local Settings\Temp
(Again, a couple files may not delete, don’t worry.)
10) Run Regedit
11) Make sure you are at the very first entry of the registry hive. (My Computer should be hilighted) then click EDIT -> FIND
12) Search for “boot.com”. If it finds an entry, delete it. Keep hitting F3 until you’ve deleted all instances of boot.com in the entire registry.
13) Scroll the left column back up to the top and hilight the My Computer again at the top of the registry hive.
14) Click Edit -> Find again and search for ‘resycled’ and repeat as in step 13, deleting the entries as it finds them.
15) Close registry editor and try opening the infected drives. They should work now.
Worked for me at least.
Posted on Apr 16, 2009
Hello, I own an acer aspire one ZG5 netbook, and today I got an error while trying to start it, the blue screen to be exact. Here's the error: A problem has been detected and windows has shut down to...
Hi Stefi,
An unmountable boot volume error means that the operating system cannot boot from the hard drive either because the boot files are corrupted, the hard drive is faulty or there is a problem with the cable connecting the hard drive to the computer. If you are booting your PC and come across a Blue Screen of Death stating UNMOUNTABLE_BOOT_VOLUME, don't despair.
You would need to repair the volume inorder to fix this issues.
To repair the volume, follow these steps:
  1. Start your computer by inserting the Windows startup disks or the Windows installation disk if your computer can start from the CD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
If this procedure does not work, repeat it, but type fixboot instead of chkdsk /r in step 5.
Hope this helps .
Please let me know if you need further help
Apr 12, 2012 | Acer Computers & Internet
Unmountable boot volume
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Nov 28, 2011 | HP Compaq DC7900 Small Form Factor PC...
UNMOUNTABLE-BOOT-VOLUME DELL LATITUDE D610 technical information: *** STOP:0x000000ED (0x86D3A900,0xC0000006,0x00000000,0x00000000)
Good day. Regarding your issue, computer hardware wears out over time, it's a fact. Your hard drive works constantly reading and writing data, and this (among other factors) may cause errors on certain parts of your system. If you receive the "unmountable boot volume" error and have an installation disk, you still have a chance to save your system.
1. Insert your XP installation disk into an optical drive and boot up your computer.
2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode with a DOS prompt.
3. Now type chkdsk /f or /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When asked to say yes or no, type the Y key on your keyboard.
5. Type exit and press the Enter key to reboot your computer.
Note: other windows version like Vista or Windows 7 have a Repair option once you use the installation disc to fix this problem.
Hope this information help in resolving your issue. Have a great day.
May 23, 2011 | Dell Computers & Internet
Unmountable boot drive error on 80 gb hitachi laptop drive
If you receive the “unmountable boot volume” error and have an installation disk, you still may have a chance to save your system.
3. Now type chkdsk /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
If all went well, you should now be able to boot back into Windows without a problem!
Aug 23, 2010 | Hitachi hts548080m9at00 80 GB Hard Drive
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
When my gateway MT6705 tries to boot, blue screen
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
Oct 18, 2009 | Gateway MT6705 Notebook
Unmountable Boot Volume Win XP
u need to reboot it .I mean yu need to have a system disk and then install it
Oct 07, 2009 | Compaq Presario 2195US Notebook
Unmountable boot volume acer 3000 aspire
Unmountable boot volume is Hard Disk Partition lost.
There are two partition on hard disk, one is NTFS & FAT32, if this two partition are damage or lost, then you have lost your data also.
Reformat on it are the best way result and put new windows system.
You can recover your pictures after reformat by using a program RECOVERMYFILES, this program even when your windows system got reformatted can recover all of it.
Please don't forget to rate me.
Thank you.
Yboyandrei
Aug 17, 2009 | Acer Aspire 3000 Notebook
Boot volume err
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps.
Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Oct 18, 2008 | Computers & Internet
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
Mar 02, 2008 | Casio QT-8000 Network Terminal
Computers & Internet Logo
63 people viewed this question
Alun Cox
