Question about Sharp Ovens
Sharp R-9H84B oven temperature not high enough if I set the oven at 400 it will beep when it comes to preheat temp but when it beeps it is on at right temp. it seems to cool.
  • Kevin Hempen May 03, 2017
    I am going to take it apart again tomorrow and I will check to see how many elements it has and if they are ok. I have changed the thermister but will check it again also. I do not quite know where it gets its logic as to the temperature. you talk of a control switch can you elaborate on this? it is a Sharp R-9H84B convection microwave. The microwave works fine it is the convection oven part having this trouble.
    Thank Kevin
  • Kevin Hempen May 04, 2017
    Stan,
    I found that the circulating fan was not spinning. I think that it is possible with out the air moving the heat road the over load out and the oven just could not do what it is intended. The bering on the fan needs replacing ands i could use a new belt.
    I have been able to run it threw a partial test but I need a better thermometer first, but I think I am on track.
    Kevin
    Genius:
  • Sharp Master
  • 2,669 Answers
Check with another gauge, if faulty some of the elements maybe out or the control switch may have a fault.
Posted on May 03, 2017
Testimonial: "I am going to take it apart again tomorrow and I will check to see how many elements it has and if they are ok. I have changed the thermister but will check it again also. I do not quite know where it gets its logic as to the temperature. you talk of a control switch can you elaborate on this? it is a Sharp R-9H84B convection microwave. The microwave works fine it is the convection oven part having this trouble. Thank Kevin"
  • Stan Ford May 03, 2017
    The switch controls witch elements are in use if the contacts are burnt the element will not come on.could be switch or element.
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Samsung oven error codes
you need the service rep or repairman
Jan 12, 2012 | Ovens
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Oven pre heats then beeps with "F 2"
Hello,If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board.
If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically.
Thanks
May 28, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven does not reach set temp
What are using to measure temp ? Are you using a grocery store bi-metal or professional thermal probe ? and further to that, how long are you waiting to check temp. after range "beeps" or announces preheat complete ? The bi-metal type thermometers do take several minutes longer to reach actual temp as opposed to the ranges temp. probe. Does this unit have the "hidden" bake element ? That sounds like a huge temp difference. These units do require an additional 10mins of wait time after announcing ("BEEP") the preheat is complete (check your manual, it should confirm this) Elements don't go "bad" it either comes on (amp draw) or it doesn't.
hope this helps.
good luck
Sep 26, 2009 | Frigidaire Ovens
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Aug 04, 2009 | GE Ovens
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Ovens Logo
Top Sharp Ovens Experts
JOHN LAPIER
Are you a Sharp Oven Expert? Answer questions, earn points and help others
