I have a Baird tv model no TE46LED BK .Tried to connect surround sound tried some many cables but nothing working need a index guide of tv can any one help plesae
2 Suggested Answers
gopakumarg43
  • 75157 Answers
SOURCE: Manual for Baird 46 led tv
Try this link to download the user manual.
http://www.brighthouse.co.uk/Global/pdfs/TE46LEDBK_manual.pdf
Posted on May 16, 2013
There's no standby light on my Baird 46" led tv model TE46LED BK. Battery's in remote are new and fuse is new in plug.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Dec 10, 2016 | Televison & Video
User maual for a 47inch lcd baird
What are you trying to wire up exactly ?
If your optical. Port glows red, its an out put.if not then its an input.
Your surround system should be the last thing on your curcit.
Everything in to the TV, ie DVD etc,then run a fibre optic cable form the TV to the surround.
May 21, 2012 | Computers & Internet
How do i hookup my magnavox mrd 210 to my lcd tv for surround sound. have tried to connect with rca wires in back of tv to surround sound system and nothing. tried side of tv and nothing. my surround sound...
Have you seen the user guide?
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000036122.pdf
The TV is intended to be an end point of the video, not a source of audio. Many TV's (monitors) don't have ANY audio, much less surround sound capability. Composite Video is theminimalist video connection for setup; Component video to the TV should suffice for viewing DVD's.
Is your TV the SOURCE of surround sound programming (via an antenna) or does the programming come from elsewhere like a Cable Box? THAT would be the source you need to tap for surround sound.
Aug 23, 2011 | Philips Magnavox MRD210 System
Hi there I'm trying to connect my technics
are you trying to use the speaker system on your tv? or are you trying to get sound from your tv to your surround system?
you will need audio patch cables!
sound from your tv to surround:
line out on tv to line in on surround
sound from your surround to your tv:
line out on your surround to line in on your tv
Aug 22, 2011 | Sony Televison & Video
How do you connect AWA plasma TV to AWA surround sound
Hi Map33_bm
It appears that your TV set is 2 channel stereo, so as there is no surround signal coded into the TV audio channels, thesurround sound does not process it.
I've posted a PDF in 'manuals' which you can check out.
Did this info help at all?
Regards, Clive.
Oct 28, 2017 | Televison & Video
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
No sound
Maybe connection error,try to review the hooked up connection maybe there might be interchange;
Just click and choose whatever connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 25, 2008 | Toshiba 50H82 50" Rear Projection...
32 people viewed this question
 Grubhead
Grubhead
