Its in an odd place compared to other cars. can u help w/advice or how to. its v6 and located by radiator??!
SOURCE: 1998 mercury mystique...where is thermostat
parts store has a manual for you for about $20 that answers both those questions
SOURCE: Where is the fuel filter located at on a 2006 Mercury Mountaineer
it should be on the inside of the frame rail
SOURCE: Heater not working in 98 mercury mystic, replaced
ok here is what you will have to do remove the fuse panel it is down by drivers feet, above it is a push button to release it down.you will also have to remove it from the two hinge pins it hangs from. flip it over so you can see back at the top corner you will find a red and green wire together with a black plug the connection is going to be burned up remove plug cut wire and replace them with new ends and plug back in the red goes towards the windshield.
SOURCE: 1993 mercury sable
I have the same problem it is starting to look like the fan keeps dieing or the temp sencor is going out i jumped the fan it runs for a bit then dies and wont come back on
