Question about LG Televison & Video
Help me please...my Lg tv one side is right but one side is upside down
My son left me this tv but as I said It has a nice picture but one side is straight and the other side is upside down
    Top Expert:
  • LG Master
  • 75,178 Answers
Corrupted firmware. An update is necessary. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Posted on May 03, 2017
SOURCE: slanted picture!!
This problem might be caused by an external magnetic field. Most modern Sony tv sets have a picture rotation control. Go to the setup menu and select Picture Rotation. Your user guide will explain.
Posted on Dec 23, 2006
ryanriopel28
  • 130 Answers
SOURCE: Lg shine, camera problem. UPSIDE-DOWN! help
Try pressing one of the arrow up or down keys on the side of the phone while in camera mode. Sorry if I'm wrong, I'm not sure about LGs but that's how you do it on Samsungs.
Posted on Aug 17, 2007
SOURCE: LG 42PC3D plasma television -- screen split down the middle
Our 42" LG picture is also split down the middle. It doesn't matter if it is cable or a DVD. I would love to know if anyone has found out the solution to this prob. The TV is only 3 years old...
Posted on Aug 12, 2008
  • 489 Answers
SOURCE: Built-in webcam takes upside down pictures.
there is a adjustment in the setting of webcam its about mirroring. check it pls.
Posted on Jun 13, 2009
  • 131 Answers
SOURCE: red line down right and left side of 42" LG plasma.
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
Posted on Dec 16, 2009
Rca tv troubleshooting
Contact the authorized service center for LG in this case. The fault you reports here, seems to be a strange one. Let the service personal to detect and make it right. Gopakumar Gopalan Google
Mar 07, 2014 | LG 42LC2D 42 in. LCD HDTV
One side of tv picture is right side up and the other side is upside down and discolored? lg 55le5400
I also have the same model and same problem . this is a picture of my screen . Please help with a solution
Aug 05, 2013 | LG Televison & Video
LG LED TV 42 inch 1080p 120hz horizontal lines and upside down picture
Sounds like a main digital processor board fault. In other words, its main board should be checked. This is a very skilled work, and a normal user can't do it with ease. Contact any expereicned service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jul 25, 2013 | LG Televison & Video
My daughter was on the computer and my son was pressing buttons annoyingly and the picture got turned upside downscreen picture upside down
the faster fix is to reinstall the video card driver..This is caused by a setting in the video card engaged by mistake ..I suggest to reinstall the driver for video device and this way it will be on default setting ...Or if you think you can manage ..just open the video control ..(either click right on desktop and select for w-7 or from control panel )..and look for rotation feature..and correct it o r..press default button to redo the settings .
Have a nice day !
Nov 02, 2011 | Samsung R519-53S Notebook
The picture is upside down
Try pressing CTRL+ALT+Down. By down I mean the down arrow which should be on the right side of the laptop.
May 13, 2011 | ASUS Computers & Internet
The left side of the LG 42" plasma TV has no
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
Nov 25, 2010 | LG 42PC3D 42 in. Plasma Television
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Jun 19, 2008 | LG 42PC3D 42 in. Plasma Television
Camera
If you're looking at the face of the phone, there will be volume adjustment buttons on the left-hand side. While using the camera, try pushing those buttons to get the picture back to the way you want it. The top button (volume up) will flip it upside-down or right-side-up. And the bottom button (volume down) will do a mirror image effect.
Apr 05, 2008 | Samsung SGH-T519 Cellular Phone
Upside down photos
it is most definatelty the same solution as someone above has stated, its as simple as pressing the 'up' key on your volume button when about to take a picture.
Nov 03, 2007 | Samsung SGH-D900 Cellular Phone
Televison & Video Logo
51 people viewed this question
Computer Repairing
Computer Repairing
