Question about Refrigerators
Lights on front of fridge are only half lit don't know how to replace
Control panel on front stops working, only freezer lights are lit, freezer and fridge stop cooling.
when half of the display goes out, it is giving you an error code telling you what is wrong with the fridge.Unplugging it simply resets the computer until the error comes back typically within a few hours.
without knowing what is lit up, it is difficult to help you so I would recommend putting the error code "which bars are lit up" in a comment so we can diagnose further
Feb 03, 2018 | LG LFX25960ST Stainless Steel French Door...
Brake/Signal Lights Problem.
Sounds like a ground problem to me. Bulbs are not getting there ground to complete the circuit so they backfed through the other bulbs.
Oct 23, 2012 | 1998 Acura RL 3.5
My whirlpool refrigerator/freezer is not cooling. lights come on, fan comes on...don't hear compressor coming on, not sure. coils are clean (they are in front). Don't know what to do next.
Switch off the fridge for few hours then before you you switch on check the continuity of the main power cord to the compressor which comes thrrough the main relay. Now the relay is activated by the thermostat/pressure switch/defrost timer.
So you will be able to trace the path of the power to activate the compressor. however if the relay clicks and shuts off the the capacitor must be checked or replaced. However if there is a heavy drain of current- use a clamp tester meter- the compresssor can be a suspect.
Please check this link for a idea of the parts.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/278/identifying-fridge-freezer-parts.html
Sep 06, 2011 | Refrigerators
Fridge lights are on,fan blows,but compressor don`t start
Freezer is freezing up, Refrigerator is cool, but not enough to cool food. Replaced the condeser fan. Lights are blinking on the front panel and wondering if any knows how to re-set or any other solutions?
Mar 12, 2009 | Westinghouse Refrigerators
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the pilot.as long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Filter status, display help
This is normal. The light is on only when it's time to change the filter. I guess you have already found the filter timer reset procedure in your owner's manual!
Enjoy your new fridge!
Mar 12, 2008 | Refrigerators
Fischer and paykle E4028
hi thanks for the question the problem is the fan motor in the freezer its not blowing cod air the the fridge side look at this part first. thanks the appliance doc
Feb 09, 2008 | Fisher and Paykel E522BRXFD Stainless...
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
