Question about Kenmore Washing Machines
On final spin my Kenmore front load washer does not increase speed just before end of cycle resulting in wash that is damper than it should be. Thank you
Kenmore model # 417.42042100 Ser # XC15002118
  • 1 more comment
  • Jerry Terry
    Jerry Terry May 03, 2017
    unable to locate clutch assembly on parts list and nothing on diagram looks like clutch assembly. another contributor said it could be a lot of issues. maybe brushes in motor!!?
  • Steven Paxlow
    Steven Paxlow May 04, 2017
    Further to my previous comment on motor brushes the other obvious and common problem is a blockage or partial blockage in the waste outlet. Check filter if machine has one make sure its clear, check waste pipe if plumbed in (Normally to kitchen plumbing) and check the sump pipe/outlet below the drum. I don't know Kenmore brand, not heard of it UK but most machines don't have a clutch system just different motor windings to change speeds, Hope this helps.
  • Rigger May 04, 2017
    About the clutch I spoke of, I apologize for that if there is no clutch, because I was thinking of my own Kenmore washer that is a TOP loader and the clutch assembly is directly underneath the drum. I had same problem you have, replaced the clutch assembly and it worked perfectly. I had a hard time finding the clutch at first ,but it was there. I finally got a good breakdown of my machine and there it was. And replacing the clutch worked. Best of luck friend.
    Problem Solver:
  • 8 Answers
Could be many causes but my first inclination would be to check/replace motor brushes...cheapest option....most call out engineers will try flogging you a new/recon motor
Posted on May 02, 2017
  • 1,460 Answers
This is caused by the clutch being worn in these newer direct drive washers. Order a complete clutch assembly from an online store for that make and model and you will receive instructions with it. Get some tools and Fix it yourself. You can get case removal instructions by typing the question "How to remove the case of..........".Really, there's nothing hard or heavy in the procedures.
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
Sep 6, 2013 - Uploaded by
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from
Nov 05, 2015 | Kenmore Washing Machines
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
The drum is hitting the back of the machine
remove the bottom front panel (2 screws) look in and on the left and right side you should see 2 shockabsorbers. They probably need to be replaced. The 4 plastic pins need to be removed. I used a socket to compress the "flanges" and a hammer to tap them out.
Apr 06, 2010 | Kenmore 44102 Front Load Washer
Kenmore Energy Eco care system won't spin at all
Kenmore ECO Care system front load washer final spinal cycle
won't shut off. Machine shakes violently.
Feb 24, 2009 | Maytag PAV2300 Top Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Mar 05, 2008 | Washing Machines
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
417.4405200 not spinning at the end of wash cycles
Does the washer was loaded when you make the diagnnostic test ?
Jul 20, 2007 | Kenmore 44072 Front Load Washer
Open Questions:
Washing Machines Logo
Sal De
 Brian Main
Brian Main
