Question about Cell Phones
Restating when i go into my tools and try to click on the display settings all that happens is that my phone restarts...
EPBX thogh Ext. No Hang
Posted on Aug 25, 2011
  • Cell Phones Master
  • 805 Answers
Dear format ur memory card if it has. it may be virrus affected. and u need to format ur phone.as a result it become ok
Posted on Jul 25, 2009
My computer keep restating randomly
If you are using Win XP,Win 7 the most obvious problem is that there is a system crash taking place, go toDesktop and then My Computer ->Right Click on it and select properties->Advanced System Setting->IN the System and Recovery click the Settings button->Then in the resultant dialog box if in System Failure section Automatically restart is check then uncheck it the next time it will not automatically restart but show you the reason of restarting, and depending on that you can sort out the problem, most probable reason may be Failure or Unstable Driver's or probably Hardware fault like overheating of CPU etc, or a failing component
Hope it helps !
Jan 05, 2013 | HP Compaq nc6400 Notebook
Schedule record application starts automatically in background when system restats
Try this:
Disabling Startup Programs in Windows For some programs, it's smart to have them start with Windows, such as anti-virus and firewall software. However, for most programs, starting them at boot-up just wastes resources and extends startup time. There is a tool installed with Windows, called MSConfig, that allows you to quickly and easily see what's running at startup and disable the programs you prefer to run on our own after startup as needed. This tool is available and can be used to disable startup programs in Windows 7, Vista, and XP.
NOTE: MSConfig can be used to configure several things other than just startup programs, so be careful what you do with it. If you're not sure about using it, just follow the steps in this article and you should be fine.
To run MSConfig, open the Start menu and type "msconfig.exe" (without the quotes) in the Search box. As you type, results display. When you see "msconfig.exe," click on it or press Enter, if it is highlighted.
NOTE: If you are using Windows XP, open the Run dialog box from the Start menu, type "msconfig.exe" in the Open edit box, and click OK.
Click the Startup tab on the System Configuration main window. A list of all the startup programs displays with a check box next to each one. To prevent a program from starting up with Windows, select the check box next to the desired program so there is NO check mark in the box. Click OK once you have made your choices.
A dialog box displays telling you that you may need to restart your computer for the changes to take affect. Click Restart to restart your computer immediately. If are not ready to restart your computer, click Exit without restart.
Aug 26, 2012 | IBM Lenovo ThinkPad L412 Notebook
I can't fix my michrophone on msn, even i tried the tools maybe because when i got the windows 7 , i saw many things has been changed on my computer , plz help
If you have a laptop you will 2 mics - try making the webcam mic default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer and configure to msn
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jul 11, 2010 | Logitech QuickCam Pro 5000 Webcam
My panasonic phone display which to Spanish and
try restoring to original setting ,phone will restart @ that time click the language selection as english
May 13, 2010 | Panasonic VS6 Cellular Phone
Stalling out while driving wiil restat fine
if its a manual then ur not riing the clutch correctly
Oct 06, 2009 | 1997 Jeep Wrangler
When i put on the phone it stays on for about 3 seconds then restarts itself.what can i do
try to replace the on/off switch maybe still press holding due to restating itself or clean the battery connector maybe cause lose contact, or replace battery.
Jul 04, 2009 | Dual Electronics N99i Cellular Phone
Restarting----Restating
first try the phone using another battery, do tyr changing the unit battery make it sure it was fully charged. iy seems that you have a weak or faulty battery pack now.
Hope this initial info/idea helps
May 30, 2009 | Nokia 7610
My phone cant finish restating/opening
REMOVE MMC BACK UP OF ALL UR DATA FROM PHONE MEMORY INSTALL NOKIA PC SUITE IN UR PC AND DOWNLOAD UPDATES FOR NOKIA MOBILE FROM NOKIA.COM INSTALL IT AND UPDATE UR MOBILE ONLINE.IT WILL FORMATE UR MOBILE AND RESET UR CODE TO 12345 AND ALSO fix ALL problem
do restore factor setting form setting menu it solve ur problems or backup ur data format ur phone use *#7370# code it remove all virus and corrupt file
i guarantee my solution is always right
plz dont forgetme to rate on fixya (blue line)
Nov 08, 2008 | Nokia 6270 Cellular Phone
Restating
The processor fan is not functioning properly ,look for its RPM in CMOS settings and also the temp of the processor . This could give you an idea of whats happening.
Apr 20, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
