Question about Garmin Nuvi 350 Car GPS Receiver
Garmin 350 cannot charge and nav at the same time
For some reason, recently when i am using the nav & plugged into the lighter, the unit goes into charging mode and the nav no longer works
    Brigadier General:
  • 4,090 Answers
Your battery is faulty. Did it come with an AC Charger? Ac chargers do a better job than the car Dc which really only manages to maintain a reasonable level of input. i suspect your internal batter is critical and either needs a thorough charge or replacement
Posted on Jul 26, 2009
Where you plug in to charge is broke
Hi.
If you broke the lighter socket on car dash, replace it.
If you broke the cable replace the cable. Here the spare:Garmin Power Cables
If you instead damaged the power socket on your Garmin, call the Garmin number listed in the owners manual. The Sat Nav must be sent to Garmin for repair:Garmin ' Contact
Next time use a Suction Mount Windscreen Holder
Regards.
Ginko
Dec 15, 2011 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot 330 charging problem
Linda,
You need to check the fuse for both the car's cigar lighter AND the one in the GPS power plug (that goes into the cigar lighter outlet). Both must be good for the GPS to charge and power up.
I don't know if your friends cord worked in you car - or hers - so you're going to have to find out if it is the cord fuse or the car fuse. Since her cord worked on your GPS, start by using HER CORD connected to YOUR GPS in both cars. If it works in her car, but not in yours, check & replace your car's cigar lighter fuse. If or when it works in both cars, disconnect her cable and connect your cable to your GPS again. Connect into your cigar lighter. If it works, you're done. If it doesn't work, disassemble the plug at the end of the GPS cord (cigar lighter end) and check and replace the fuse if blown. You should be good to go at this point.
Please rate this reply if found to be helpful - good luck!
Jul 07, 2010 | Garmin StreetPilot C330 GPS Receiver
My Garmin nuvi 780 will not turn on. When I turn on, the Garmin logo shows on the screen. However, when "Loading Maps" is displayed, 1-2 seconds later the screen goes blank. This occurs when the unit is...
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
Apr 03, 2010 | Garmin nuvi 780 GPS
Garmin 1390T Won't turn on - Unless Plugged in car lighter
theb battery is faulty or has not received a proer charge time to allow it to run. If after charging for a longer time 5-6hrs it still plays up return it for a replacement or warranty repair
Jul 19, 2009 | Garmin nuvi 200W GPS Receiver
Cant use the garmin 350 while charging
The solution is really easy. Works in the car or usb charger or whatever.
Once you insert the car charger, wait till the pc connection picture comes.
Than unplug the car charger.
Re-insert it as soon as the picture goes off.
Voila. It is ready to use now!
Feb 08, 2009 | Garmin nuvi 350 GPS Receiver
Charging while driving(using the cigar plug)
I too just got mine from Santa... it's designed to operate while plugged into the lighter. It also charges the Li ion battery. If the Garmin screen comes on while you are using it I would suspect an error or what ever. (you DID move the little switch on the top left corner to unlock didn't you?) Just call their number 800 800-1020 and ask them. They were most helpful and were there well after the hours posted in the instruction book.
Jan 03, 2009 | Garmin nuvi 250W GPS Receiver
Can my Garmin 610T be used whilst charged in the car
Fully charge the device before using it...did you plug any sd cards into it?
Jul 03, 2008 | Garmin nuvi 350 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin 350
easy solution...you need to keep this plug above attach to the the Garmin 350...when charging in the car or at home ...plug the power source to the back8dac8e5.jpg. Hope this will help...i had the same problem.
Feb 21, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350
Heres what to do:
- Connect to computer using USB cable
- Flip up antenna and hit reset button.
- The unit should power up.
- Then put unit on wall charge to get a full charge.
That should do it if not call 1-800 800 1020.
Feb 25, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
184 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
