8700aww. Does not always fully drain. Do I replace the pump or the water sensor?
Initially would not drain at all. I found a quarter at entrance to drain pump. Removed quarter. Now intermittently does not drain fully. It drains down but no completely. I have removed the sensor hose from the water level sensor and blew through it to clean any obstructions. Pump is $150 and level sensor is $50. Which should I replace or am I missing something??? KJ
  • 99 Answers
SOURCE: LG Tromm Model # WM2075CW doesn't drain - water everywhere!
This is joyce
I hope you have not been waiting long for this answer, go to the website lg.com dowload your document on your washer put in your model # first and then it will give you all the info you need on that machine even trouble shoot it and codes. I hope this helps.
thanks,
joyce
Posted on Feb 07, 2009
daddyo742001
  • 70 Answers
SOURCE: air conditioner dripping water
Try pouring some bleach in drain.
Posted on Jun 28, 2009
QueenJLyn
  • 3 Answers
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
  • 64 Answers
SOURCE: Whirlpool dishwasher 2966 draining failure
take the airgap apart. located on top of sink. clean out and reassemble.
Posted on Aug 26, 2009
rylee_smith
  • 8619 Answers
SOURCE: Maytag Quiet Series 100 Help - diswasher always
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 03, 2009
Is it normal for 2 inches of water to remain in space where filter container is positioned...whenever filter is removed water is in the compartment where filter rests
In my experience the lowest section of the washer has always retained some water about a cup or two. If the one way valve(check valve) in the drain hose has failed or residue trapped in it more water will drain back at the end of cycle. You can see from the image the volume of additional water that would be trapped in the hose that if the one way valve leaks; the water in the hose would leak back into the tub.
the drain hose is required to go above the drain connection to prevent back flow into the washer. the one way valve in the drain hose is required to prevent back flow into the tub in the event of a blocked drain.
I hope that this helps.
Check Valve Replacement part 8268375 Whirlpool Dishwasher Repair
In some washers the check valve is critical because the pump reverses during the normal cycle. The attached video is an example of the check valve replacement in a Whirlpool. I have found all washers are similar.
You can usually hear when the pump has emptied the tub by a change of pitch from the motor. If you quickly open the door and observe the remaining water level that is as low as I would expect.
Jan 05, 2016 | Dishwashers
I have an amana front load washer nfw7200tw10 I replaced the drain pump and still get ND error
I had the same problem, not sure it was your pump, load it with a bucket of hot water and some bleach, turn it on and let it run through a short cycle, the hot water and bleach can clean the sensor and the screen in the bottom going down to the pump, did water drain out when you took the lines loose, if it did its a good sign, most people dont realize you use only a quarter or less cup of soap in this washer, it will get the sensor water sensor dirty and the washer thinks it has water when it doesnt, the pump cant drain cause there is no water, . try the hot water trick, rmember use a bucket and as hot a water as you can, probably hair sudds and who know what is blocking the sensor, mine was hair, from my little girl, Matt
Jan 27, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
Drain pump leaks after quarter removed
Just put the quarter back into the pump!
Just kidding.
Sounds like a seal was damaged. Did you find the quarter at the pump? close to it? Perhaps it didn't damage a seal but the pump itself. You may need to find exactly where the water is coming from so you can determine what part needs to be replaced.
May 04, 2010 | Whirlpool WTW6400SW Cabrio Washer
Theres a loud clicking type noise when washing machine is running
I drained the machine from the filter and then removed the cap and found 2 hair grips and coins at the entrance of pump which was stopping it pumping the water out,cleaned out filter and was sorted,
Dec 22, 2009 | Washing Machines
Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Sep 26, 2009 | Maytag MDB5100A Dishwasher
LG dishwasher ld14aw2 error
Did the owner of the LG LD-14aw2 that was giving the OE error get the problem resolved?
With an OE (Drain Error), it means that the dishwasher is not fully drained out in spite of 5 min. drain operation. First step of the trace the entire path of the drain hose to the sink drain. Be certain that ther is no blockage in any of it.
It that does not resolve the problem, remove the lower spray arm and the screws that hold the sump area down. Open up the area and inspect everywhere for debris that could be blocking the drain area.
Next step would be to replace the drain motor.
With the LG dishwasher that is giving an IE error: Double check that the water valve supplying the dishwasher is fully open. Next, with the water turned off, open the connection between the inlet pipe (hot water) and the dishwasher inlet valve. Clean the screen of all debris/minerals that often build up there.
If problems continue, check and replace the inlet valve.
Thanks for reporting back what you have found. Good Luck!
Dec 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Whirlpool duet washer
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
